96 Spec ITR vs. 98 Spec ITR Wheel Bearings
Old Oct 29, 2010 | 12:30 PM
SOHCunderdog's Avatar
Default 96 Spec ITR vs. 98 Spec ITR Wheel Bearings
Will the 98 Spec (5 lug) ITR front wheel bearings work with the 96 Spec (4 lug) ITR hub?
Old Oct 29, 2010 | 12:51 PM
BlueIntegraBoy's Avatar
Default Re: 96 Spec ITR vs. 98 Spec ITR Wheel Bearings
The 98 spec uses the CRV wheel bearings, while the 96 spec uses normal Integra/Civic wheel bearings.
Old Oct 29, 2010 | 12:54 PM
Thanks for the info bro.
Old Oct 29, 2010 | 06:43 PM
jdmwarrior's Avatar
hey get the full assembly wheel bearing from autozone. its easy to install.
Old Oct 30, 2010 | 06:09 AM
Not located in the U.S. My cousin had some 98 spec bearings lying around so thats why I was asking.
Old Nov 9, 2010 | 04:24 AM
Ok so I ordered 44300-S5A-004 wheel bearings from hondapartsdeals.com and they sent me 44300-S5A-008 wheel bearings.
Having a hard time finding any info on here about that part number. Can anyone confirm that they did sent me the right bearings?
Old Nov 9, 2010 | 04:26 AM
Most likely the same part but different manufacturer.
Old Nov 9, 2010 | 04:29 AM
Used google (google ftw!) and found this response below:
"I don't know where you're getting parts from, but all of the wheel bearings I have for '94-01 Integra are 79mm, not 78 . . .
'94-01 Integra uses the same front wheel bearing as a '92-00 Civic EX (part no. 44300-S04-A02) and all '01-05 Civics (part no. 44300-S5A-008), so you may want to try at Honda instead of Acura."
Looks like I got the right bearings :D
Old Nov 9, 2010 | 04:31 AM
It has NTN in brackets next to the description so you may be right.
Old Nov 9, 2010 | 07:19 AM
94rs-turbo's Avatar
it's because honda will discontinue and PN because of changing manufactor or changing the part so they give a new replacement number at Honda we call it "superseeded part number" no biggie though
EGtypeR408
Suspension & Brakes
Dec 17, 2012 07:03 AM
DBada FM
Dec 8, 2009 09:44 PM
NoLeftTurn
Sep 9, 2009 05:11 PM
MrHeeltoe
Nov 16, 2004 05:35 PM
benmasters
Sep 20, 2004 07:51 AM
