Accord weird noise HELP!!!
2000 accord ex v6 auto 4 door. Noticed a kinda humming or howling noise that sounds similar to a wheel bearing being out. The noise is only in the rear axle and makes worse sound on the passenger side but does make some noise on driver side as well. when you bank toward the driver side it momentarily shuts up. When you go towards pass side it doesn't change at all. Noise is predominate at 40 and 75 mph. Replaced hub and bearing assembly on pass side. as well as new brake rotors and pads. just figured out caliper was sticking on pass side and replaced. A week ago when I fixed caliper I thought it had changed the noise quieter and now a week later it seems almost the same as before. I can't believe with all the accords out there like mine that I'm the only one with or that has ever had this problem. HELP its driving me crazy!!!
my_hondaetown
Aug 2, 2012 10:56 PM
