h2b help!!!!!!
Old Oct 29, 2010 | 08:28 AM
miked16203's Avatar
Default h2b help!!!!!!
i have an h22a in a 94 bubble using the same hardness plug and play i use a b17 ecu tuned for my gsr for now 255cc walbro fuel pump injectors form a v6 acura rl or legend not sure.. the car has spark dont kno how much its needs but does have spark also i put 3 grounds and firing order is fix but the car doesnt turn over it cranks and fire ball type effect out the intake mani when i hit the gas timing is the last thing i wanna do i just want make sure everything esle is fine the swap came together and was untouch just dropped it in and thats wut happen need help... call me for mor infor 1203 737 0650
Old Oct 29, 2010 | 01:21 PM
gstrudler's Avatar
Default Re: h2b help!!!!!!
Uh, how about using the right ecu with a base map that is for the engine it is on That and knowing what size injectors you are using and setting the tune for it.
Old Oct 29, 2010 | 03:40 PM
Ass$nyper's Avatar
Pirate General...YARRRR
That might be a logical first step.
Old Oct 30, 2010 | 11:01 AM
miked16203's Avatar
Used a p28 did the same thing also using 245cc injectors
soo to be 550cc swAping after get it started
gs-r94coupe
Oct 22, 2010 10:06 PM
jays93eg6
Southeast (Sales)
Apr 24, 2006 07:24 PM
gen2teggy
Apr 9, 2006 12:03 PM
