1990 accord HP increase
My 1990 accord currently has a full exhaust, short ram intake, iridium plugs, new distributor, bored out throttle body, short shifter, adjustable coil overs, 16's rear upper tie bar and energy suspension sway bar links.
I was thinking of getting a stage one clutch and getting the heads and intake manifold ported out for a few more hp and tq. Is there anything else I could do without breaking the bank to get some extra power besides forced induction or have I meat my peak as far as power?
TB - no additional power without additional mods
short shifter - no power
coilovers - no power
16's - no power (probably weigh more than stock)
sway bar endlinks - no power
SRI - doesn't really add power on F22's
exhaust - doesn't really add power on F22's
clutch - no power
ported w/out other mods - no power
You're far better off either a turbo or getting a performance camshaft to actually gain any power. You're OBDI so getting a camshaft and say like a chipped P28 would be your best money spent to get actual power.
plugs - no additional power (minus regained from old stock)
clutch - no power
clutch - no power
Honestly, much like Themuffinman said, go with a camshaft! It will make much more power as it directly effects your motor!
Im shooting you a PM right now!
If there is anything I can help you out with, shoot me an email!
Randy
Randy@Bisimoto.com
clutch - no power
clutch - no power
I had an AEM V2 cia, went to TAS Pro got the $95 Hybrid Polished Intake w/ a K&N. Got me 4 1/4hp, & 5ftlbs tq. Sold the AEM on craigslist. Put $30 in my pocket. I bought a Delta 272 cam for my F22A4 along with a cam gear and valve spring set and got 18hp on the dyno. Just the powerband was alot higher.
tru that sounds pretty nice. chances are that when i get the heads, and intake manifold ported that im going to get a cam, with a light weight cam gear even if the cam gear is not adjustable.
Honestly I would save my money and get an H22 swapped in there. It is the world's easiest swap. You use all Honda motor mounts. can keep AC and Power steering if you have them. And face it, almost 3 times the power of the F22a going to H22a. Okay, not quite 3 times, but definitely 2 times the power for sure. The time you spending in saving for it would be worth it in that this is a much more build able block as well, so you aren't at the end, you have room to grow if you want (as in these have been built to bring huge power if you want).
My .02 cents...
My .02 cents...
If you're looking for a cheap way out, go with the basics. F22a6 runner, h22 plenum and h22 t body, pt6 ecu, 92-93 ex camshaft and 90-91 ex exhaut manifold. That was my first setup, loved it. Then I stepped up and went bisimoto products and gained about 91whp at around 6500 rpm. Now I'm back down to a f20b sir-t motor.
Depends on your budget. The first one suggested is all available from your local junkyard. Second is from randull. Third suggestion is from hmotors. Good luck.
My .02 cents...
My .02 cents...
Get the Evolution Intake manifold adapter and a H22 Intake manifold. Or find a H23 manifold, that will help out a bit also. I have a Euro R manifold on my GF's F22 and it works well.
The f22b1 heads that come in the 94-97's have a more aggressive head design which allows more flow so it would not be a bad idea plus the f22b1 swaps make about 10 more horse's than the f22a does.
The F22a head flows way better than the F22b head. Also, the F22b1 came with 145hp; the F22A6 came with 140hp and its non-vtec. Throw a p12 ecu in it and you're at 150hp (theoretically). The vtec in the F22b1 was intended more for fuel economy than performance.
alrighty thanks for the advice and the info.
fastbrakes
Jul 28, 2003 05:04 PM
