AIR CARBON MANIFOLD + Sunk2 TB 1450aud Shipped to USA!!
as tittle states
you guys know what this is!!!!
AIR Carbon Fiber Intake Manifold + Skunk2 Throttle body + Rc 440cc injectors with plugs
Fuel Rail not forsale!!!!
$1450 Shipped to USA
Paypal payment to be safe for both parties
I'd say it's lighter and doesn't get as hot as metal does..... plus it looks badass.
I've always wanted one of those. Baller. Should fit both GSR & B16/B18C5 applications. Does it come with the IACV relocator?
Take a look at the link and see the benifits of this manifold.
www.advancedinductionresearch.com
Lower Weight - Because they are made out of lightweight aerospace materials we are able to lower the overall weight of our parts significantly. Total weight with all fittings attached for our part is 4.5 lbs vs. 16.5 lbs. for the stock manifold. That's just over 1/4 of the weight of the stock intake!!!
High Strength - Tested to 50 PSI and 250 Degrees Fahrenheit for extreme forced induction applications.
Heat Absorption - Inch for inch, aluminum has 48% more heat storage capacity than carbon fiber composites. A stock manifold absorbs power-robbing heat and then unloads it into your intake charge when you accelerate. Our carbon fiber intake effectively absorbs 87% less heat than the stock manifold.
Increased Power - Our design and proprietary molding process allow us to create a seamless part with smooth internal and external walls. This allows us to realize the full design potential to achieve better airflow which translates into a dramatic increase in performance.
Tony from T1 Race ran one on his Teg a couple years ago.
95 integra
Nov 20, 2008 04:04 PM
Tbone
Feb 21, 2006 07:44 PM
