1995 swap h22 h23 auto to manual
ok i have a few ???
I have a 1995 Accord ex 4dr auto
and i want 2 put an H23 trans in manny but it dont have a LSD in it but my auto does can i put it in there
also can i put a steering knuckle from a 98-01 on a 95. and where can i find a big brake kit for the 95 also i have a h23 but the front motor mount is broke of the guy said they had to too put a turbo on u ever herd
and i want 2 put an H23 trans in manny but it dont have a LSD in it but my auto does can i put it in therealso can i put a steering knuckle from a 98-01 on a 95. and where can i find a big brake kit for the 95 also i have a h23 but the front motor mount is broke of the guy said they had to too put a turbo on u ever herd
Cheap big brakes, get accord V6/prelude Vtec calipers. Use a 25T bracket and V6 rotors, direct bolt on. Get good rotors and pads. Anything bigger than that is overkill.
H22s, you will pay around $1000-$2500 depending on if it has a trans and if it does what type of trans it is. No getting out of it, unless you score big at pick a part.
Slow down, write your sentences/questions coherently so they make sense and edit your original post. As it stands I have no idea what the hell you are trying to do.
