Subaru build you honda kids may like. Slammed/fitted/shaved & tucked
Old Oct 27, 2010 | 07:43 PM
subwrxkid's Avatar
Default Subaru build you honda kids may like. Slammed/fitted/shaved & tucked
This was my car before:
https://honda-tech.com/forums/honda-acura-28/big-photoshoot-wrx-jtuned-subiesport-1924124/
and this is it now.
img]http://erictong.com/dmoneysti/23.jpg[/img]
subwrxkid's Avatar
Default Re: Subaru build you honda kids may like. Slammed/fitted/shaved & tucked
Mods list:
Exterior:
JUN Auto Bumper (Authentic)
C-West side skirts
HKS Kansai Service rear diffuser
ARC Magic splitters
Ganador mirrors
Varis carbon fiber B-pillars
Top Secret titanium tow hook
Chargespeed carbon fiber brake ducts
04-05 rear tail lights
04 STI rear bumper
Velocity Carbon V1 trunk lid
Kakumei carbon fiber window spoiler
McCulloch 6000k H1 HIDs
JDM STI headlights
JDM STI rear aprons
JDM STI grill w/STI emblem
JDM Subaru pink star badge
JDM STI hood scoop
JDM Subaru rain guards
Carbing aluminum under panel
30% tinted windows by Shades of Gray
STI license plate bracket
Hella Supertone horns
VKInnovations carbon fiber wiper cowl
Summit Racing dzus fasteners
Rolled & pulled front/rear fenders
Takata low down ramps (show use)
Paint/body:
BAS-F Ultrasonic Blue Mica w/dark aluminum & purple flake
Shaved & wire tucked engine bay
Shaved: factory antenna, side markers & window washers
Painted: Trunk, radiator brackets, timing belt covers, brake booster, sub frame brace
Coating/finishing:
All powder coating done by Martin at Liquid Powder Coats
All chroming done by Brian at RB chroming
All ceramic coating done in Jet-Hot 2000
All carbon fiber done by Vince at VKInnovations
Interior:
BRIDE Stradia Maziora edition w/Andromeda backs
BRIDE brackets/sliders
BRIDE optional gradiation center pads
BRIDE wrapped door cards in gradiation
BRIDE wrapped back seat in gradiation
Black suede headliner & visors
Black suede rear deck lid
VKInnovations c/f interior trim pieces
Shaved/painted b & c pillars
Takata harnesses (x2)
Pioneer AVIC-D3 in dash dvd/mp3/cd/nav/ipod
Alpine Type-S 6 ½ front speakers
Alpine Type-S 5 ¼ rear speakers
Alpine Type-S tweeters
Grimmspeed internal antenna
Key!s Racing semi-cone 325mm steering wheel
Works Bell Rapfix II quick release
Works Bell short boss hub
Works Bell Rapfix flipper
STI floor mats
STI shifter trim
STI limited black carpet
STI I/C spray switch
STI key blank
STI Cluster
STI e-brake handle
STI C/F 5mt shift pattern
STI chrome door handles
STI aluminum door sills
STI full pedal set
JMF custom sheet metal rear fire wall
Garage spec shifter extender
ARC polished titanium shift ****
Autospeed dead pedal
Taylor polished battery box
Broadway rear view mirror
Prodriven Auto full interior red LED conversion
YourLEDshop full interior white LED kit
Lotek dual gauge pod
Defi triple gauge hood pod
Defi control unit
Defi BF Amber 60mm guages
-Boost
-Oil Temp.
-Exhaust Temp.
-Oil Pressure
-Water Temp.
Wheels/brakes/suspension:
Work Emotion CR Kai 18x9.5 +30 WMB finish
Project Kics R40 Neo chrome lug nuts
Dunlop Direzza Sport Z1 Star Spec 255/35/18
Project µ 355mm big brake kit w/ SCR-PRO rotors
Project µ Teflon/steel braided brake lines
Project µ B-force pads front & rear
Brembo rear calipers (custom powdercoated Pmµ teal)
Rear Brembo adapter kit w/DBA 4000 series rotors
Stoptech SS braided rear brake lines
Custom ABS delete with Earl’s -3AN fittings
Motul RBF-600 brake fluid
Stance AL+ PRO coilovers (8k/6k)
Race alignment (-3F -2.5R)
ARP extended studs F/R
Megan Racing C-pillar bar
Whiteline steering rack bushings
Whiteline roll center kit
Carbing front strut bar w/msb
Carbing 8pt subframe brace
Cusco rear strut bar
Cusco rear V-brace
Cusco lateral links
Cusco trailing arms
Cusco 22mm front sway bar
Cusco 22mm rear sway bar
Hotchkis front/rear endlinks
Perrin rear sway bar mounts
Engine/head specs:
RAW Performance (Axis) Signature Series block:
• 2.5L STI semi-closed deck case (8.5:1)
• Darton Ductile iron sleeve liners
• Modified forged EJ257 crankshaft
• ACL race main & rod bearings
• Custom Pauter machined forged rods
• Custom & coated CP Forged pistions (100mm)
• High performance pistion rings
• Fully balanced & blue printed
• ARP head studs
• Cometic head gaskets
• Raw Performance shimmed STI oil pump
• New STI water pump
• STI Group-N Kevlar timing belt
• Factory Subaru engine gasket kit
RAW Performance (Axis) Signature Series heads:
• Custom Kelford 280/280 camshafts (11.3mm lift)
• Custom hand porting work
• 5-Angle intake valve job
• 3-Angle & radiused exhaust valve job
• Supertech oversized intake valves (+1mm)
• Supertech oversized Inconel exhaust valves (+1mm)
• Valves lapped into head
• Supertech dual valve springs
• Titanium retainers- new spring seats
• Subaru valve stem seals
• Shimless Subaru buckets
• Flow bench tested
Engine/turbo/dress up:
Ultimate Racing turbo kit (ceramic coated in Jet-Hot 2000)
HTA86 1.06 A/R
2.5” ID up-pipe
Gruppe-S UEL header (ceramic coated in Jet-Hot 2000)
Hydra EMS v2.6 w/wideband
Hydra flat foot shift/launch control cable
JMF custom intercooler kit w/Garrett 24x12x4 core
JMF custom coolant overflow tank
JMF custom coolant tank
JMF custom power steering tank
JMF custom FPR/distribution block bracket
JMF custom dual pulley setup
JMF custom cnc’d alternator bracket
JMF oil cooler core bracket
TiAL “Q” 50mm bov
TiAL 44mm external waste gate
ATP -4AN oil feed line w/.035 restrictor
JDM TGV deletes
Cusco motor/transmission mounts
Koyo Radiator
ATI super damper
Unorthodox 2-pc polished pulley set
Crucial Racing thermostat
Gates Racing accessory belt
Hayden slimline fans
JIC Spartan DE type-1 full titanium exhaust (80mm)
P & L braided power steering line
P & L -8AN head breather adapters
Custom -8AN crank vent system
Peterson Air/Oil separator
Port matched intake manifold and tgvs
Ported throttle body (64.5mm)
Setrab oil cooler core (-10AN)
Mocal sandwich plate w/built in thermostat
JDM STI pink oil filter
Apex'i AVCR electronic boost controller
Apex'i turbo timer w/HKS harness
Vibrant vacuum lines
Agency power pitch stop
Samco radiator hoses
ARC radiator caps (x2)
ARC titanium radiator shroud
ARC oil fill cap
Gallery Original Dress up colored bolts (56pcs.)
Project µ brake & clutch reservoir caps
Project Kics magnetic oil drain plug
NRG polished hood dampers
Full wire tuck by Wkderf
Fuel system:
Ultimate Racing 1260cc injectors
RAW Performance -6AN fuel rails
TurboXS surge tank setup
Bosch044 external fuel pumps (x2)
Walbro 255l/ph fuel pump
Aeromotive A1000 platinum series fuel pressure regulator
Aeromotive fuel pressure gauge
Aeromotive 10-micron fuel filter
Aeromotive aluminum fuel filter bracket
Earl’s distribution blocks (x2)
Earl’s swivel-seal fittings
Earl’s Auto-Flex HTE hose (-8AN feed, -6AN return)
Jay Racing –6AN check valves (x2)
Jay Racing Bosch pump -6AN inlet fittings
Drivetrain:
PPG 1-4 straight cut gear set (3.08 / 1.87 / 1.32 / 0.95 / std)
PPG 1-4 billet selector forks
PPG LSD front differential
PPG synchros
Powder coated Transmission case w/all new bolts
ACT XT 6-puck sprung clutch
ACT Streetlite flywheel (13.9lbs)
Custom -3AN clutch line
07’ 3.54 R180 (painted, chromed rear diff cover, earls ¾”npt plugs)
Redline lightweight shockproof gear oil
Motul gear 300
Kartboy 5mt short shfiter
Kartboy front shifter bushings
Kartboy rear shifter bushing
Kartboy exhaust hangers
Kartboy trans cross member bushings
Kartboy rear subframe bolts
Kartboy rear outrigger bushings (race)
TIC rear diff mount bushings (race)
TIC shifter pivot bushings
TIC shift linkage bushings
Driveshaft shop 600hp rear axles
Driveshaft shop 600hp front axle bar upgrade
Old Oct 27, 2010 | 07:47 PM
Folgers's Avatar
damn thats a bad bitch lol. very nice, bay surprised me
Old Oct 27, 2010 | 07:54 PM
da_unknown's Avatar
TUFFF..... thats **** is wicked thats my favorite subbie
hai_tech's Avatar
wow look amazingg
Old Oct 27, 2010 | 07:57 PM
EJ_ALLMOTA's Avatar
AMAZING!!! thats all i say...
Old Oct 27, 2010 | 08:02 PM
codyJDM's Avatar
killin it
Old Oct 27, 2010 | 08:06 PM
YAGYAGAN_JDM's Avatar
**** goes hard!
Old Oct 27, 2010 | 08:07 PM
subwrxkid's Avatar
Thanks guys, you all gave me ideas to bring into the subaru game. When I first posted about shaving my bay in 07' they all laughed and said I couldn't do it. bahah Now look, still the only one with one done. lol
Even though it's not finished up, when it's all said and done it will make 700whp+. Gotta love darton sleeves and o-ringed blocks. haha
Old Oct 27, 2010 | 08:08 PM
Rainer'sEK's Avatar
Wow I love it!!!
Old Oct 27, 2010 | 08:12 PM
nels00n's Avatar
LOOKS AND 700AWHP
Old Oct 27, 2010 | 08:14 PM
StreetLethaleg6's Avatar
DAYYYyyyyyUUUUUmmmmmmm! strong finances Op!
Old Oct 27, 2010 | 08:22 PM
Original.'s Avatar
B-B-BAAALLLIIINNN!!!
Old Oct 27, 2010 | 08:33 PM
subwrxkid's Avatar
haha you guys are wild wit the replies. lol! I can't stop laughin.
I wish I had pics to show off the undercarraige. The bottom is painted, every suspension piece was replaced with cusco bars, chrome rear diff, painted carbing subframe, carbon driveshaft, powdercoated subframes, etc. Everything under the car is just as clean as the top. lol!
Old Oct 27, 2010 | 08:41 PM
White Fox's Avatar
MOTHER OF CHRIST THAT IS THE BEST THING I'VE EVERRRRRRRRRRRRRRRR SEEEEEEEEEEEEEEEEEEEEEEEEEEEEEENNNN!!!!!!
Old Oct 27, 2010 | 08:48 PM
Original.'s Avatar
People laughed when you said you were going to shave the bay? LMAO, I like my bays like my girls.. shaved.
Old Oct 27, 2010 | 09:01 PM
subwrxkid's Avatar
haha well they didn't laugh, because on nasioc I have a big following, but they did say it couldn't be done clean like a honda/vw. I think I did pretty good considering I still had to make big power. If I was only stage 2, I could have deleted so much more but oh well. Big power and shaved. Holla
I coulda ditched power steering, no air separator, no ebc, etc etc. I think the power steering turned out gangster with custom tanks and -an. lol
Old Oct 27, 2010 | 09:14 PM
HardLuckfoto's Avatar
So will this be a show queen? Either way I freakin love the car! Looks amazing
Old Oct 27, 2010 | 09:49 PM
dinged's Avatar
god that bay is so empty it's ridiculous! get that thing on a lift i wanna see the underbody! what center console is that? that's not the stock wrx one is it..? very, very clean car though, i'm loving everything about it. except the mirrors
Old Oct 27, 2010 | 09:53 PM
SikhCiviC's Avatar
Wow
Old Oct 28, 2010 | 01:29 AM
dirtySOHC's's Avatar
pretty cool that you took ideas from the honda scene and incorporated it into your car. **** looks amazing. fat pockets!
Old Oct 28, 2010 | 03:59 AM
Slepton's Avatar
The whole car looks great. I love the project mu setup. You sir must have VERY deep pockets or a **** load of maxed out credit cards! LOL
Old Oct 28, 2010 | 04:27 AM
KevonN's Avatar
I has a crayon!
wow great changes for sure...I saw it a couple of times at e-town in it's earlier stages and fell in love with it back then. It's even so much sicker now. Props to you my friend, I look forward to seeing it again in person.
Old Oct 28, 2010 | 05:16 AM
CrxSiR-GNY's Avatar
wow, great car!
Old Oct 28, 2010 | 05:21 AM
Axix24's Avatar
damn, thats a new build... you stepped it up with the tucked bay.. most subie owners don't bling out their bay or tuck it and etc..
