fully built b20/vtec questions.
Old Oct 27, 2010 | 12:54 PM
egGO400's Avatar
Default fully built b20/vtec questions.
i have just finished my b20/vtec 4 door teg. with that said its time for a road tune. im wondering what my revlimiter should be set at, and what is a good point to set my launch limiter at.
my mods are as follows:
95 4 door integra base car 1300.00
cam gears obx purple with lock nuts/washers! 75.00
gsr head 225.00
milled 75.00/jet washed 40.00
crower cams stage 1 325.00
titanium valves, valve springs and retainers .. 350.00
valve adjustments 55.00
new oem hardware for head 89.00
wrinkle powder coated valve cover 75.00
jdm vtec solenoid 75.00 w/new gasket/screen
blox cam block 20.00
honed/bored block b20/85mm, jet washed, hot tanked. 325.00/120.00(block)
arp studs 125.00
Gator blue gsr timing belt - 84.00 shipped
Oem 22t vtec water pump - 50.00 shipped
Oem obdII b20 oil pump - 115.00 shipped
ARP rod bolts - 60.00 shipped (using stock LS oem rods)
ACL rod bearings - 59.00 shipped
Cometic 85mm head gasket - 80.00 (paid & left swerve)
12.9:1 YRP 85mm aluminum pistons and hastings rings - 279.00 shipped
Walbro 255lph fuel pump - 65.00 shipped
Precision 440cc injectors - 225.00 shipped
Password jdm dry carbon "whale *****" intake - 210.00
b18/b20 oem crank 200.00
new hoses all around 30.00
thermostat 15.00
oil/tranny fluids/rad fluid/zinc compound etc 95.00 x 2
final change after break in with synthetic 145.00
royal purple stay cool additive/distilled water mix for radiator 20.00
2 x Bride vios low max frp gradation seats w/sliders - 1520.00 shipped
f1 kms carbon racing mirrors with custom plates 155.00
sparco 3 pt harnesses silver/black 225.00
golden eagle vtec kit w/dowles 16.00
braided fuel line 25.00
greddy braided radiator hoses 125.00
10.2mm vision racing race wires 45.00
ngk plugs 7.00
skunk 2 intake manifold 225.00
aem fuel rail 125.00
aem fpr/gauge 25.00
pro sport digital oil pressure gauge 85.00
pro sport air/fuel gauge 275.00
dual guage flush dash pod 30.00
custom rota rims 600.00 shipped
pirelli tires 230.00
skunk 2 pro coils 775.00
buddy club camber kit (rear) 75.00
tri strut brace 50.00
aluminum spark plug wire cover 20.00
p28 chrome chipped ecu 145.00
vtec b16 dizzy 185.00
6pt BDR roll cage 185.00 plus install of 350.00
blox shifter **** 40.00
vision racing open end lugs 60.00
blox racing locking lugs 40.00
mishimots mini me radiator 90.00
fab slim fan 150.00
dc header 100.00
vibrant cat 75.00
powder coated custom exhaust(cat back) 125.00
tints 120.00/450.00 paint
2001 front end conversion 200.00
dual halo headlights 125.00
smoked clear fogs 55.00
jdm black honda badges 22.00 ( shaved all other badges)
viper alarm 275.00 installed
full hid 50.00
tilt license plat holder 20.00
short throw shifter 75.00
energy suspension bushings all over .....
new oem serpentine belts 45.00
new engine grounds 10.00 x2
lightened flywheel 7lb 125.00
stage 2 clutch/pressure plate exedy 225.00
JUST ADDED...
JDM gsr lsd tranny with progressive bushings/30k - 1000.00
carbon dinoc sheet 4ft x 11ft 400.00
radar detector 125.00
infiniti bass tube(amplified) 225.00
monster wiring kit 75.00
clarion touch screen/navi/etc. 450.00
memphis full internals/crossovers w/lifetime warranty 275.00
400watt amp for fronts 125.00(used)
chrome chip/tune by andy 300.00
theres def alot im forgetting plus addtional costs for mess ups/people screwing me on parts (thanks guys karma is a bitch) shop costs if something was needed, machine shop visits etc.... but you get the idea..
questions:
what should my rev limiter be set at?
launch control rev?
any suggestions on oil/fluids after "break in"?
i will be posting pics as soon as she is leaving the shop, and if anyone has any questions about this build and needs help feel free to pm me and i will answer any questions i can. its been a long journey and just about 17K spent to make this tegger completely unique and well all motor vtec.
thanks in advance.
Old Oct 27, 2010 | 01:15 PM
PyroProblem's Avatar
Default Re: fully built b20/vtec questions.
you forgot the drain plug washer... JK
Id set the rev limiter about 500-700 rpms past peak hp. I dont see an advantage to winding out the motor if its not making power, but theres different opinions on this.
Launch control will need to be set at the track. Depending on what tires you run,pressures, and track/street condition, it will probably be a trial and error thing.
Just curious...Why such a mild camshaft?
Old Oct 28, 2010 | 04:52 PM
egGO400's Avatar
i have higher compression and i didnt wanna go ***** out, and blow it.. i have alot invested in this all motor project and its gonna be a fun daily/scca whip. plus im using 93/94 pump gas.. so i didnt wanna go up past that.
Old Oct 28, 2010 | 05:21 PM
Combustion Contraption's Avatar
Fully built = dyno tuned, not street tuned.
Old Oct 28, 2010 | 06:26 PM
egGO400's Avatar
i feel like dyno tunes are good but not as accurate in a way.. i mean there amazing but if you think about it its like training to run a marathon on a tread mill not takin it to the streets and feeling the real hills, rocks etc.. i dunno maybe im wrong but to me a road tune u hit unexpected hills, turns etc and different condidtions and u have ato adapt the tune to that.. am i wrong?
Old Oct 28, 2010 | 07:42 PM
You're wrong.
Loaded dyno's can simulate any sort of driving scenario and tune for it. Why "fully build" (as opposed to "half build"? I never understood that.) an engine, and then NOT put it on the dyno so that it can reach its full potential?
Old Oct 28, 2010 | 08:34 PM
Gotta dyno tune it. Pretty much the only way to find MBT..
And its kinda hard to tune the part throttle unless you ride the brake or find a reaaally long hill and have cordination like a ****!
I think there should be very little street tuning if its properly dyno tuned. Someone correct me if Im wrong.
Old Oct 28, 2010 | 10:11 PM
89canefighter's Avatar
dyno tune it then tweak it buy running it on the street or hwy.
Old Oct 29, 2010 | 11:51 PM
oskrB18's Avatar
Nice build man ! I agree with Combustion "Fully built = dyno tuned" give us some numbers
Old Oct 30, 2010 | 12:24 PM
bambam's Avatar
I agree with the statement that limiter should be set about 5-700 Rpms above max power. Depending on gearing, ideally, when you shift 5-700 rpms past peak power, your rpms drop below your peak power so that you will come across your peak power point again in the next gear. Gearing is an important aspect of shift points. Your rod bolts, bearing clearances, rotating assembly weight, rod strength/material, and valve spring capacity are the most important deciding factors on whether you can safely rev higher.
Todallybuilt
Feb 14, 2018 04:43 AM
CRXguy_88
11
Mar 28, 2012 01:25 PM
Charltons_Trix
Mar 25, 2008 06:17 PM
Mark
51
Dec 15, 2007 08:55 PM
84DA69
Nov 24, 2006 02:05 PM
