FS/FT: 93 Del sol-totally rebuilt b18-front conv.
NOW ACCEPTING TRADE OFFERS, PLUS CASH HIGHLY ENCOURAGED-INTERESTED IN HONDA/ACURA'S, MAYBE A TRUCK, MUST DRIVE PERFECT ON THE HIGHWAY.
ONLY 7200 MI'S ON BODY AFTER OVERHAUL AND 3200 MI'S ENCOUNTING ON MOTOR AFTER OVERHAUL.
137xxx mi's original on body before parked for overhaul
please bump if viewed, Thanks!
Exterior:
99-00 Civic Si Conversion Front end
Si Front lip
Freshly repainted last summer-Redline Orange Pearl-09' OEM Honda Color-stored for winters
Shaved Emblems
Paint Matched Mesh Grill
Halo Headlights w/ HID retrofit using Audi A4 projectors and Ford Slim Ballasts
17" ADR design rims wrapped in Evo Z tires w/ a little over 2500 mi's
4 wheel disc w/ new Thermoquiet pads and new rear calipers
Tokico Blue lowering springs and struts
fairly NEW all front end bushings, tie rods, balljoints and alignment
Removable Targa top that stores in trunk
**Also comes with extra touch up paint.
Interior-
stock seats
All Stock panels
Crossover speakers in the doors
Dual Storage compartments behind the seats
Alpine Alarm System
Comes with Boost Gauge and pillar pod (Wires & hose already ran)
Panasonic Headunit
Engine-
OBD1 B18b (LS) swapped motor- Freshly Rebuilt with even Compression in all Cylinders- HAVE ALL RECEIPTS FOR MACHING WORK DONE AND PARTS BOUGHT
3 angle valve job, new valve stem seals, valve guides, acid cleaned
honed, decked, milled, valves resurfaced and cleaned, pistons cleaned, crank micropolished and line bored
New Distributor
New Water Pump
Optima Yellow top battery, relocated to the trunk.
Semi Tucked Wiring in Engine Bay
Crower Stage 2 Turbo Cams, Springs and Retainers
Cometic .060" Headgasket
Gates Timing Belt
HASport Billet 70A Race Mounts
F1 Stage 3 Clutch w/ Lightweight Flywheel
ACL Race Series Bearings
255lph Walbro Fuel Pump
B&M Fuel Pressure Regulator with Gauge
New Starter
No Power Steering, No A/C, No cruise control
Energy Suspension Shift Bushings
ARP Headstuds
ARP Connecting Rod Studs
**Full Turbo Back Exhaust
**Has Stock LS ecu
**Have all receipts for machine work done and parts bought.
I think thats everything, but i may have missed something, sorry if i did.
I'm asking $5,500 obo
This is a for sale thread, not an opinion thread, if you don't like it, keep it too yourself.
Exterior:
Si Front lip
Shaved Emblems
Interior-
stock seats
All Stock panels
Alpine Alarm System
Panasonic Headunit
Engine-
New Distributor
New Water Pump
Gates Timing Belt
New Starter
ARP Headstuds
**Has Stock LS ecu
^^ yeah i thought the same, but when i bought the car many moons ago, the sideskirts were already installed, so there were holes in the fenders and i didn't like that, i've been contemplating taking them off but HATE the holes there. The FMIC isn't on anymore, but it was turbo D before i did the b18b rebuild & swap, and the B was gonna be turbo'd, but i didn't have the gumption or money to finish the small stuff for the turbo set-up w/ moving and starting school so i sold the kit.
I haven't "run" it since i built the motor because the motor was still in it's infancy.
--> 219--> i'm not sure what that was supposed to mean but i'm going to take that as a compliment. so thank you.
TTT
TTT
