AWD DYNO for SALE STEAL of STEALS great for any new shop!!!!!!
Old Oct 27, 2010 | 07:00 AM
EVO 2 K's Avatar
Default AWD DYNO for SALE STEAL of STEALS great for any new shop!!!!!!
I have a AWD Dyno DYnamics Dyno for sale this was brought for $110,000 comes with everything. you do not need to dig into any ground or have a crazy high ceiling just a nice solid ground. Comes with ramps and screen and everything you need to get this thing going. Only reason for selling is because we are moving to a new shop and dont have space for this type of dyno. Perfect for a new shop does awd rwd and fwd cars.
any questions call or text 631 278 5300
located in NY (Long Island) can be delivered
asking $80,000
dyno is a little dirty from the turbo cars that were on the dyno
Old Oct 28, 2010 | 07:58 AM
EVO 2 K's Avatar
Default Re: AWD DYNO for SALE STEAL of STEALS great for any new shop!!!!!!
This is an DynoDynamics 450DS AWD Ver. 7.1.4 4WD Release
Dyno Dynamics - AWD450DS Chassis Dynamometer Ver. 7.1.4
Here is all the bells and whistles I purchased:
http://www.dyno.com.au/dyno/controll...owAWD450DSPage
Applicable Vehicles:
• Rear wheel drive
• Front wheel drive
• 4WD/AWD cars, recreational vehicles
• 2WD/4WD race cars
• Sport utility vehicles
• Light commercial vehicles
• Motorcycles
Transmission Types:
• Front wheel drive
• Rear wheel drive
• All wheel drive
• Locked Front:Rear AWD
• Full time AWD
• Viscous coupled AWD
• Intelligent european AWD (Volvo dog clutch)
• Variable ratio Front:rear
Vehicle Wheelbase Measurments:
Minimum wheelbase (89")
Maximum wheelbase (138")
Power, Tractive Effort, Torque and Speed:
BOTH AXLES:
Maximum power graphing 2,000 kw (2,700 HP)
Max. tractive effort graphing 41,400 N (9,300 lb)
Max. roller torque graphing 4,500 Nm (3,300 ft lb)
Max. axle torque graphing 12,300 Nm (9,000 ft lb)
Max. engine torque graphing (Note 2) 4,200 Nm (3,000 ft lb)
Max. power steady speed 900 kW (1,200 HP)
Max. tractive effort steady speed 27,600 N (6,200 lb)
Max. roller torque steady speed 3,000 Nm (2,200 ft lb)
Max. axle torque steady speed (Note 1) 8,200 Nm (6,000 ft lb)
Max. engine torque steady speed (Note 2) 2,800 Nm (2,000 ft lb)
Inerface: (I purchased every option available)
*Vac pressure boost
*Inlet air temperature
*High speed Air:Fuel ratio/Lambda
*Thermo-couple inputs
*Auxiliary inputs
*Fan control
The dyno comes with two (2) fans including a 48" circle fan and a snail fan!
My dyno has absolutely no issues or failures and I keep it in perfect condition. I will also be including a black/white checkered race floor I installed around the dyno, new tie down straps, and command module.
Absolutely no issues or failures of any kind. I grease the rollers every 2 weeks and perform any maintainence neccessary often. If you would like pictures, videos, or anything else, please do not hesitate to ask, or call me personally at 631-957-8464!
Thanks!
Any failures or issues at all?
Old Oct 29, 2010 | 04:49 AM
EVO 2 K's Avatar
can i get dyno bumps lol
Old Oct 29, 2010 | 06:04 AM
Fibercation's Avatar
Seen it all on h-tech!
Location will help ya
Old Oct 29, 2010 | 06:32 AM
95ProjectEJ1's Avatar
BUMP
Old Nov 1, 2010 | 06:31 AM
EVO 2 K's Avatar
thanks for that !
Old Nov 1, 2010 | 06:50 AM
EVO 2 K's Avatar
honda t is the best!!
Old Nov 2, 2010 | 05:57 AM
EVO 2 K's Avatar
the one and only h tech dyno bump
Old Nov 3, 2010 | 06:03 AM
EVO 2 K's Avatar
dyno bump!!!
Old Nov 4, 2010 | 04:43 AM
EVO 2 K's Avatar
i know someones shop needs this
Old Nov 4, 2010 | 05:50 AM
boostedb20ek's Avatar
Is that $80,000 shipped? Lol
Old Nov 5, 2010 | 05:26 AM
EVO 2 K's Avatar
yes it is.
Old Nov 6, 2010 | 11:49 PM
EVO 2 K's Avatar
GREAT DYNO BUMP
Old Nov 6, 2010 | 11:52 PM
hillssol95's Avatar
wishing i had 80,000 right now...o well BUMP!
Old Nov 8, 2010 | 06:49 AM
EVO 2 K's Avatar
thanks for the bump
Old Nov 8, 2010 | 05:06 PM
EVO 2 K's Avatar
she needs a new home!
Old Nov 8, 2010 | 06:05 PM
powerwheels86's Avatar
bump for a dyno!!
Old Nov 9, 2010 | 05:08 AM
EVO 2 K's Avatar
thanks 4 the dyno bumps!!
Old Nov 10, 2010 | 05:39 AM
EVO 2 K's Avatar
got lots of calls on this just not a real buyer yet
Old Nov 11, 2010 | 05:46 AM
EVO 2 K's Avatar
dyno bump!! thanks
Old Nov 12, 2010 | 05:22 AM
EVO 2 K's Avatar
just used it last night still does the trick lol
Old Nov 12, 2010 | 06:41 AM
Contender_h22a's Avatar
bump for viewing
Old Nov 15, 2010 | 05:59 AM
EVO 2 K's Avatar
thanks 4 the bump
Old Nov 16, 2010 | 07:38 AM
EVO 2 K's Avatar
i no some tuner out there needs a dyno!
Old Nov 17, 2010 | 05:30 AM
EVO 2 K's Avatar
no dyno bumps!!!
