clutch engagment issues d16z6
ok so i recently replaced my z6 trans with a y8 trans. while doing that i replaced my clutch and flywheel with a f1 spec 2 clutch and aluminum flywheel. when i first put it in i bleed the line correctly. my problem is that the clutch pedal has lots of play in it. also the clutch does not engage until the pedal is half way. my third problem is that the pedal is way to soft(i can press it with 1 finger) at first i thought thats what i get for buying a cheap clutch! after break in the clutch dosnt slip at all but the other problems are still there. im guessing its the master or slave cylinder. i read the how to on adjusting the pedal but it confuses me with the lack of pics. sorry for writing so much. just want to give you guys all the info so i can fix this. thanks in advance.
eman96
Sep 4, 2015 06:31 AM
immalooser
Apr 14, 2010 08:01 PM
adjust, bleed, clutch, d16z6, engage, engagement, issues, pedal, replacement, slipping, soft, transmission, wont
