Does anybody know if a OBDII to OBDI conversion harness can be interchanged between 99 Gsr and 01 IT
Old Sep 20, 2002 | 02:39 PM
PYITR821's Avatar
Default Does anybody know if a OBDII to OBDI conversion harness can be interchanged between 99 Gsr and 01 IT
I have a P28 and the OBDII to OBDI conversion harness but I don't know if the harnesses vary from 99 to 01. I tried the harness in my brother's 99 Gsr and it didn't work, so I was wondering if it might be for my car. The guy that I bought it from said it was OBD2b to OBD1 for 99+ so I thought it would work in my brother's 99 gsr. What is OBD2b anyways? Thanks.
Old Sep 20, 2002 | 02:43 PM
sneakychaos's Avatar
Default Re: Does anybody know if a OBDII to OBDI conversion harness can be interchanged between 99 Gsr and 0
There are two versions of OBDII... A & B. Thats probably your problem.
Don't know the exact differences, other then they only share 2 of the 3 plugs for the ECU. The third goes into two different slots.
Old Sep 20, 2002 | 02:45 PM
PYITR821's Avatar
Is OBD2b for 00-01?
Old Sep 20, 2002 | 02:51 PM
Austin's Avatar
Is OBD2b for 00-01?
Yes...Honda/Acura changed their ECU connections for the model year 2000 and beyond. So a 1999 ecu will not work on a 2000 car.
Austin
Old Sep 20, 2002 | 02:58 PM
PYITR821's Avatar
Is OBD2b for 00-01?
Austin
Thanks.
Old Sep 21, 2002 | 02:56 AM
sgT's Avatar
sgT
Correction.
00-01 integra and 99-00 si use the same harness.
its called a 99 adapter because the civic switched first.
Old Sep 21, 2002 | 07:46 AM
kenji's Avatar
25 Year Member
sgt is right.
However, not all companies/individuals wire up their '99-'00 Civic/'00-'01 Integra OBD2 to OBD1 harnesses up for both the Civic and Integra. There is a slight difference between the two.
My harnesses are wired to work in both the '99-'00 Civic and the '00-'01 Integra without any modification.
-kenji
Old Sep 22, 2002 | 07:54 AM
Blown90hatcH's Avatar
Yup. My harnesses as well are wired for universal applications.
J
Old Sep 22, 2002 | 08:01 AM
Mr Hammond's Avatar
a/k/a Jomo
Check Hondata's website...they show what the 96-98 harness' look like and the 99-00...they use a civic as a base.
SiB16A
Mar 20, 2009 12:09 AM
blackie
Jul 25, 2005 05:53 AM
BoostJockey
Mar 11, 2005 09:28 PM
shadykit
May 24, 2004 10:16 AM
shadykit
May 12, 2004 05:22 PM
