what b18c1 parts to keep
Old Oct 26, 2010 | 06:40 PM
horn12007's Avatar
Default what b18c1 parts to keep
alright guys gonna try to keep this short. I have just rebuilt an ls vtec. Its in the car, but not complete. I need an obd1 dizzy and gotta figure out the wiring and some other smaller stuff.
So in my hunt for a dizzy I couldn't find any in my area. So I found a 95 b18c1 motor that ran when before being pulled out of the car. It is complete with everything and all the accesories for only $150! yea what a steal. The head is good. I don't have it in my possession yet so I can't get too happy, but I already talked to the guy about it.
Ideally I would rather rebuild this than use my lsvtec, but I've gotta get my car out of the garage and the lsvtec already has forged internals so its not possible right now. Im gonna use the dizzy off the gsr and im gonna keep the head for sure. What else should I use/or keep? The rest of the stuff I will probably sell? the motor has 200k so there are certain things im not gonna use.
Old Oct 26, 2010 | 10:28 PM
mouab18c1's Avatar
Default Re: what b18c1 parts to keep
$150 for a GSR motor? damn i'd keep everything ahaha
Old Oct 26, 2010 | 10:47 PM
horn12007's Avatar
yea dude its a steal and technically it would still run, but has low compression on 1 cylinder. Im almost thinking to keep the whole thing. and slowly build it. maybe Il build the b18c1 for as an NA motor since my lsvtec is built for boost.....
Anyways even if I do part it out what should I keep....also is the crank pulley off a c1 and a b18a1 the same? I have an aftermarket crank pulley and would like to go back to stock if it is the same
Old Oct 27, 2010 | 11:08 AM
horn12007's Avatar
Hell yea got the motor. It is more than complete. Has alt, power steering, ac pump, intake, part of the wiring harness.....everything. Im stoked
Old Oct 27, 2010 | 01:24 PM
mouab18c1's Avatar
Keep whatever you want, sell what you can. And no I dont think the b18c1 and b18a1 have the same crank pulley.
Old Oct 27, 2010 | 02:24 PM
horn12007's Avatar
thats alright Il just use the aftermarket pulley
Old Oct 27, 2010 | 07:51 PM
madblkscientist's Avatar
dam i need a gsr block i envy u
Old Oct 27, 2010 | 08:41 PM
horn12007's Avatar
you know what I may part it out. how much would you pay. pm me or text me at 618-980-6865
Old Oct 27, 2010 | 08:42 PM
horn12007's Avatar
im still debating whether to keep it or part it out......
Old Oct 27, 2010 | 08:48 PM
mouab18c1's Avatar
Its a bad block with low compression in cylinder 1? If it was me I would give you $5
Old Oct 27, 2010 | 08:54 PM
horn12007's Avatar
ahhh hahahahahaha. I havent checked it out could easily be piston rings. If you get any used block you gotta hone it anyway
Old Oct 27, 2010 | 08:55 PM
horn12007's Avatar
il sell you a buck double for $5
Old Oct 27, 2010 | 09:03 PM
lmao^^^^^^^^^^^^^^^^^^
Old Oct 27, 2010 | 09:05 PM
horn12007's Avatar
hahahaha yea I thought that was a good one too....but im serious about it though
Old Oct 27, 2010 | 09:50 PM
mouab18c1's Avatar
Not true, only if its a MESSED up block
Old Oct 28, 2010 | 07:51 AM
horn12007's Avatar
not true? so you wouldn't hone your block if you rebuilt it?
Old Oct 28, 2010 | 09:02 AM
mouab18c1's Avatar
If im gonna rebuild it then of course. but if its a good running block then of course not
Old Oct 28, 2010 | 10:52 AM
horn12007's Avatar
lol. thats why I said it had low compression in cylinder one. It had a leak down test done and the air goes into the oil pan. so either rings or possibly a jacked up cylinder, but most daily driver cars that haven't been ran hard lean toward bad rings.
so in saying that you would have to tear down and rebuild the motor..........aww **** just realized I didn't mention anything about no compression in 1 cylinder
Old Oct 28, 2010 | 10:53 AM
horn12007's Avatar
what I meant to say in my first post is that it was running when pulled but the compression issue
Old Oct 28, 2010 | 10:56 AM
mouab18c1's Avatar
Boost it and blow it up then ill buy it for a rebuild.
Old Oct 28, 2010 | 01:50 PM
horn12007's Avatar
hahaha yea right. tear it up more nah don't think so. Ive already got a built lsvtec for that
95gsrsedanlawl
Sep 20, 2008 07:01 PM
Strelspeed
Mar 5, 2008 06:28 PM
95egGold
25
Aug 12, 2007 02:26 AM
Ninjaboi_on_X
Dec 17, 2003 12:27 PM
kydragger
Feb 5, 2003 07:21 AM
