ITR Crank-Pulley Questions/Alternator Bracket Questions.
Old Oct 26, 2010 | 05:34 PM
Redcoupe's Avatar
Default ITR Crank-Pulley Questions/Alternator Bracket Questions.
Heres the verdict. I'm putting my 98 back together with my JDM 96 spec ITR longblock. I sold off my USDM 'sleeved' turbo B18c5 motor but kept the crank-pulleys I had for it.
Now. I bought the 96 spec from Steve at HMO about 3 years ago. It came with a cracked crank pulley and I believe I got another one at some point in time.
When I put it back together though. I have 3 crank pulleys with no real markings or anything on them. They 'fit' and two have the EXACT same sizing. One has little holes drilled in them.
Here is my question now.
Does anyone have pictures of what the different year B18c and B18c5 motors had crank pulley wise? Kinda curious.
Also with all of the switching of motors I've acquired a pile of alternator brackets. Most being the usual cast piece while a couple being thing steel looking brackets.
Any have the brackets or 'code' that came on their motor? Pictures prefer'd.
Once I get this thing together. All this extra **** is going 'byebye'.
Thank you for your time.
-Jarrod
Old Nov 2, 2010 | 11:28 AM
Redcoupe's Avatar
Default Re: ITR Crank-Pulley Questions/Alternator Bracket Questions.
So far what I've came up with is...
a friend of mine's stock 01 ITR has a crank pully with the same sizing and small holes pre-drilled into his aswell.
The altenator bracket is a cast piece upper and lower.
And USDM motors came with the alumnium underside bracing?
Old Nov 2, 2010 | 12:52 PM
94rs-turbo's Avatar
sounds right, the drilled holes if from honda to balance the pulley. I remember top and bottom being cast though.
pic shows the same
"And USDM motors came with the alumnium underside bracing?"
which part do you mean
did you swap the crank angle sensor and oil pump?
if your going to run stock ecu you will get a code or you can bypass it if you must
Old Nov 2, 2010 | 03:24 PM
Redcoupe's Avatar
pic shows the same
[URL=http://img249.imageshack.us/i/img3405s.jpg/][IMG]http://img249.imageshack.us/img249/4038/img3405s.jpg[/IM
My swap has been OBD1 for about 4 years now. I'm not a purist in that sense.
I was just curious as to which brackets were which.
The part I mean is the brace that replaces the two L brackets that support the motor/transmission together.
(edit* thanks for the response though )
Old Nov 2, 2010 | 05:13 PM
94rs-turbo's Avatar
oh the itr tranny brace?
ya usdm itr's came with those
Old Nov 2, 2010 | 07:16 PM
Redcoupe's Avatar
I'm assuming that's brand new? Not the best picture of the inside of the crank pully but I appreciate the insight.
-Jarrod
Old Nov 2, 2010 | 07:24 PM
94rs-turbo's Avatar
cleanest swap I've ever seen OMG
Old Nov 2, 2010 | 07:26 PM
Redcoupe's Avatar
Originally Posted by Si_chRis
That's how it came from HMO. Absolutely squeaky clean.
Haha. Mine was from HMO but I don't remember it being like that. My B16 swap was but not my R. Then again I bought a 96 spec and I just bought the long block.
I LOVE HMO.
mrchris1979
Jul 23, 2009 09:44 PM
'00_GSR/R
Jan 25, 2009 11:41 PM
B18cFreak
Apr 28, 2008 09:52 PM
HiChanDC2R
Jul 12, 2006 05:59 PM
jmk2888
Jul 29, 2004 05:17 AM
