Transmission & Drivetrain Gearboxes, Differentials, Clutches
GSR tapered bearing help
Old Oct 26, 2010 | 04:42 PM
ashb82's Avatar
Default GSR tapered bearing help
I got a gsr tranny i am replacing syncros in. I was thinking i would put new bearings and seals in it also. I have put lsds in ls and b16 tranny with no problems. But how do check the clearance on the tapered bearing so i know what shim to use. I keep reading about preload and stuff but im a little confused.
Old Oct 26, 2010 | 05:04 PM
Aquafina's Avatar
Default Re: GSR tapered bearing help
Buy the OEM tool or make your own and set the preload. Tapered bearings don't use a clearance.
Old Oct 26, 2010 | 05:36 PM
ashb82's Avatar
what is the tool
Old Oct 26, 2010 | 06:05 PM
Aquafina's Avatar
Lets you turn the diff using a torque wrench with the case bolted together to measure the preload.
Old Oct 26, 2010 | 06:27 PM
ashb82's Avatar
thanks i think i can make that i work at a machine shop. Just found a integra service manual that show pic of the tool
Old Oct 30, 2010 | 03:28 PM
vanny_david's Avatar
convert your GSR tranny to the new ball-bearing + shims
all you need is a set of feeler gauge to measure the diff-to-housing clearance
93h2beg
Jul 21, 2010 05:19 PM
MRXMUFFIN
Aug 22, 2006 08:35 AM
SlowTeg
Aug 6, 2002 08:06 PM
D
Mar 25, 2002 03:26 PM
