98 accord trans problem
Old Oct 26, 2010 | 04:08 PM
z28miket's Avatar
Default 98 accord trans problem
Hello to all, I am new to the site, obviously, I am hoping to get some input on a problem with my daughters car.
It is a 2.3 auto car, when in park and neutral there is a grinding, whirring noise coming from trans that goes away when in gear at idle, but driving you can hear it also just not as loud.
Converter, bearing?
Anyone know what this is?
Thanks Mike T
Old Oct 27, 2010 | 12:59 AM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: 98 accord trans problem
There is a known problem with 98-02 automatics. Factory rebuild units still have the same issue.
Originally Posted by Wikipedia, Honda Accord
Despite the Accord's reputation for reliability, the V6 models were plagued by transmission failures and were even included in class action law suits against the company (4 cylinder models were also affected, but not to the same extent). This caused the Honda Corporation to extend the warranties for the 2000 through 2001 models to 7 years or 109,000 miles (175,000 km). 1998,99 and 02 cars were considered on a case by case basis. Yet no formal recall occurred. In Canada, recall letters were sent out to owners who fell within a certain VIN range, this warranty was later re-extended for some owners to 7 years 11 months in length.
May want to have the car checked out at the local Honda dealer if the car falls within the mileage. They may do a goodwill replacement.
Old Oct 27, 2010 | 04:47 AM
z28miket's Avatar
Thanks for the info.
I have heard some of the rebuilt ones have the same issue, and I was told to drain trans and check magnet for bits of metal and if it is just fuzz not to worrry.
I will do this today.
Thanks again much appreciated!
Old Oct 27, 2010 | 03:24 PM
MAD_MIKE's Avatar
MM Gruppe B
The issue is the transmission will wear out the clutch packs seems 2nd is the problem. You may not get that much fuzz on the bolt if its clutch material and not ferrous metal.
FWIW when the transmission in the '95 EX crapped out it began to make whirring sounds as well.
Old Oct 28, 2010 | 01:51 AM
z28miket's Avatar
Yea I drained the fluid and found some fuzz on the bolt , no big chunks , but when I poured out the fluid from the pan there was guite a bit of small shiny particles in the bottom.
It shifts fine 90% of the time but sometimes it won't shift into 2nd unless you let off the gas.
Guess I need to find a donor.
Thanks again,
Mike T
a32e5s7
Jan 14, 2013 12:11 AM
accordohio
Feb 7, 2007 04:07 AM
nsutanto
Jul 3, 2006 10:49 PM
btran
Jan 14, 2005 07:22 PM
98ACCORDguy
Oct 29, 2004 12:40 PM
