ABS System Affecting Cruise
I just recently found out that my right rear speed sensor is bad. After trying to clean the sensor, the ABS Light still comes on. What could be wrong? Also, does the ABS System affect the cruise on my car for it does not work?
Check ABS light again to find code? And maybe REPLACE the bad sensor (assuming the light is triggered by it) rather than clean it?
And I have not heard/seen any information where ABS would cause cruise not to function. The VSS can do that however.
*edit*
You also make no mention of your car year/model/trim/mods/etc
*edit*
