Transmission & Drivetrain Gearboxes, Differentials, Clutches
B16 hydro trans help
Old Oct 25, 2010 | 05:20 PM
travishoward's Avatar
Default B16 hydro trans help
I have the version without LSD. 2nd grinds bad. But only after 2000 rpms. 3rd grinds after about 4000 rpms. Can I replace the synchros with hydro carbon Gsr synchros? Will this make my gears longer? I can get all the synchros barely used for 100. That's why I'm asking
Old Oct 25, 2010 | 07:26 PM
Aquafina's Avatar
Default Re: B16 hydro trans help
Check the mounts clutch system first (master and slave first, then clutch itself). If its good, then split the trans. Synchros alone won't fix the grind if its not the clutch system or mounts if its grinding at that low of an RPM. Synchros don't affect the gear ratio.
Old Oct 25, 2010 | 07:42 PM
dang.. im just hoping i dont have to buy a whole new tranny, or rebuild this one completely..
the_branster
Nov 19, 2010 04:44 PM
z06eateR
Jul 29, 2010 01:32 PM
MIGPA26
14
Apr 17, 2009 12:55 PM
Will_H
Sep 4, 2008 08:32 PM
g2tegsown
Jul 15, 2007 07:36 AM
