NEED HELP, Prelude transmission housing feel stuck
Old Oct 25, 2010 | 11:21 AM
k20dude's Avatar
Icon2 NEED HELP, Prelude transmission housing feel stuck
its my first time opening up a honda prelude transmission, it's from a 99 honda prelude. the reverse didn't work so i open it up to see what wrong with it, don't know anything about transmission but then i try just to put the housing back on and seem like it's stuck or something, it had like a small finger gap between housing and case, even if i try lightly taping it with rubber hammer it just wont go in. please help
also do anyone know anythings about what wrong with the reverse not going in, when i putting it in reverse and letting go of clutch, it only grind, i try going it into first and then reverse really fast but still nothing, i try pushing car back and forth then in reverse, but still nothing, it only grind, does anyone have any idea what is wrong and what i need to replace
all gear shift perfect no grind at all. only reverse grind, but i did happen to miss shift on third gear on freeway while doing a high end race with a M3.
Old Oct 25, 2010 | 12:26 PM
1GPlusSH's Avatar
Default Re: NEED HELP, Prelude transmission housing feel stuck
what didn't work that you wanted to see what was wrong?
Old Oct 25, 2010 | 03:28 PM
q16racer's Avatar
http://www.prelude power.com/forums/...257179&page=29
remove the space
Old Oct 29, 2010 | 12:26 PM
k20dude's Avatar
the reverse was out, it wouldn't go into reverse and it only grind, but all gear work fine, no grind or nothing on all gear except for reverse.
Old Oct 29, 2010 | 12:36 PM
k20dude's Avatar
bump
Old Oct 30, 2010 | 02:18 PM
k20dude's Avatar
it's kool i got it all work out already thanks.
Old Oct 30, 2010 | 03:33 PM
q16racer's Avatar
go to the link i gave you....
Old Oct 31, 2010 | 04:07 PM
viper_boy403's Avatar
If it wont go back together, either your countershaft snap ring hasnt seated properly, or your shift fork rod(s) arent going onto their holes. To seat the countershaft, first make sure the snap ring is spread open. Flip the transmission upside down and lightly bounce it on the outer casing. That should cause the countershaft to drop and the snap ring to seat in it's groove on the bearing. If it's the shifter rods, you'll need to wiggle the shifter arms around while trying to seat the casing down
Old Oct 31, 2010 | 05:42 PM
q16racer's Avatar
getting the countershaft in the snap ring is easier to just use a pry bar to push up on the 4th gear through the shifter box.
Speedplease
Jul 16, 2006 06:29 PM
theoverachiever
Apr 12, 2005 11:35 PM
americ_ian
Mar 21, 2004 08:45 PM
prelude2boost
Dec 23, 2003 03:04 PM
ryans
Dec 16, 2001 07:11 AM
