Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
what are other drain plugs on Pilot Transmission
Old Oct 24, 2010 | 12:43 PM
vclifford's Avatar
Default what are other drain plugs on Pilot Transmission
I noticed there are other drain plugs on Pilot transmission. On one side there is standard drain plug which is being used to drain ATF but on the other side there are two drain plugs. I was guessing they might be used to drain other portions of Transmission like torque converter etc. I did not open them. Does any one know what are they. But if that was the case the replacing all the fluid in one shot will be easy.
Regards,
Old Nov 3, 2010 | 04:15 PM
cresscrx's Avatar
Default Re: what are other drain plugs on Pilot Transmission
your probably looking at the differential drain and fill plug... it gets serviced every 45-60k miles takes 80w90 instead of atf.
Lithel
Dec 9, 2008 09:09 AM
HondaTom
Jan 15, 2006 10:19 AM
Drew Peacock
Feb 7, 2003 05:28 PM
Flux
Jul 29, 2002 09:46 AM
