Albins Gear Sets available now from SpeedFactory Racing
We are excited to be able to offer the Albins Gear Sets to the Honda-Tech community.
Albins has appointed SpeedFactory Racing (working in conjunction with Bullhead Gears) as a stockist and preferred supplier of the Albins Extreme Duty Driveline Products related to Honda B series and K series vehicles.
Speedfactory Racing is also fielding enquiries and sales related to the new K series 1100hp rated 4 speed drag dogbox for K series powered cars.
NOTE: This pricing is subject to change daily due to exchange rate variances from day to day.
If you would like to purchase please call the shop for more info or payment options:
253-566-4331 or email sales@speedfactoryracing.net. Thanks!
$6890 for B series Helical Dog Set
1-4 set = $6890 Ratios: 3.0 / 2.0 / 1.39 / 1.09
Dogset includes Upper Handcuff and Final Drive = Ratios: 4.4, 4.09, 4.7 Custom are available.
Albins Off Road Gear is the largest high performance gears manufacturer in the Southern Hemisphere. They specialise in engineering and production of driveline components for extreme duty applications.
This is our gearset of choice, with amazing reliability and performance under WOT 10,500+rpm full throttle shifts at 50+psi of boost in our 1100whp Outlaw car. Unique design features include replaceable dog rings on 3-4 gears, low dog count with pent-roof design for ease of shifting, and lightweight semi-floating 3/4 slider design.
Albins helical cut design offers high strength, low operating noise levels, and copes with shaft and case deflection/distortion better than similar straight-cut designs.
This is your ultimate choice for a top notch dogbox in your B series racecar!
*Manufactured to ISO 9001/2000 quality standards.
*Billet high-alloy proprietary grade steel.
*CAD engineered custom tooth profiles.
*Robotic CMM scanned for tooth profile perfection.
*Manufactured as a direct-fitment replacement for standard units.
*Features "Handcuff" brace in place of 5th gear when used as a 1st-4th drag set.
*Optional 5th gear available.
*1st to 4th gear ratios of 3.0 / 2.0. / 1.39 / 1.09.
*Comes with Helical cut Final Drive, available in 4.09, 4.4, 4.7 ratios.
*Anti-fatigue shot peening treatment as standard on all components.
*Designed for use in vehicles with power levels around 1100HP.
$3850 for B Series Helical Synchro set
1-4 set = $3465 Ratios: 3.0 / 1.87 / 1.33 / 1.0
Final Drive = $1190 Ratios: 4.4, 4.09, 4.7 Custom are available.
"Albins has a 25 year history of motorsport drivetrain manufacture and is currently the largest high performance transmission manufacturer in the Southern Hemisphere. Albins Off Road Gear is an Australian Proprietary Limited Company that specializes in the design and manufacture of drivetrain components. Our capabilities include the ability to produce; individual gears, axles, drive flanges and ring and pinions right through to complete unit, sequential shift transmissions. Utilizing ISO 9001 2000 certified manufacturing techniques, our team of over 40 employees implements up to the minute design trends to create product that is currently in use in such places as Dakar Rally, Baja 1000, Australian V8 Supercars as well as various European and Australasian Rally Championships. "
The Albins gears are made from a proprietary grade steel billet that is then cut and heat treated to exacting standards then cross-checked via a robotic CMM machine that analyses any discrepancies brought about by heat treatment. This process is part of Albins ISO 9001/2000 quality assurance and can be done prior to the final anti-fatigue shot-peening process which is another point of difference we love about this product. Fatigue life can be extended on certain components by up to 8 times that of a non-treated component and when we are talking gears, this is a major plus with the Albins product and results in less pitting and wear. Ratios work great for both street and track and pricing is extremely competitive for a product that has come out of a factory that makes product for factory rally teams, Dakar rally podium finishers, Baja 1000 winners and top level touring car teams across the globe.
We have tested the synchro set undergoing both street and track testing for over a year now in the 800-950whp range with zero failures, and has run 9.4 sec in the 1/4 mile at 164+ mph during testing. These gears are a very exciting product for those who need extreme strength along with quiet, streetable operation for their xtreme street/strip vehicle.
Designed as a direct fitment 1-4 set (use stock 5th gear), into stock B series casings, these gears are helically cut and are designed to share the thrust loads more evenly through the B series gearbox casing unlike some straight cut gears. Another added benefit to the Albins design is REPLACEABLE 3rd/4th engagement cones/dog teeth that are usually built onto the gear. With Albins, even if you damage the dog teeth, you can replace this part without the added expense of having to purchase a whole new replacement gear!
K Series Synchro:
$3850 for K Series Helical Synchro Set
1-4 set = $3465 Ratios: 2.93 / 1.70 / 1.19 / 0.93
Final Drive = Add $1190 Custom are available.
Picture is shown with Final Drive.
The factory K Series transmissions are well known for gear failures when used in 400+whp turbo applications. This gearset addresses that need as the ultimate solution! Unique design features includes replaceable dog rings for 1-4 gears and helical cut for quiet operation. 1st gear only is straight cut in this set to meet design parameters.
These gears are a very exciting product for those who need extreme strength along with quiet, streetable operation for their extreme street/strip vehicle. Can be used in 5 or 6spd configurations.
Available 1st-4th gear ratios:
Option 1 - 2.93 / 1.70 / 1.19 / 0.93
Option 2 - 3.0 / 2.0 / 1.47 / 1.10
Available Helical Final Drive Ratios: 4.38, 4.77, 5.08, 5.09, 5.23, 5.31, 5.42, 5.83
*Can be used with synchro or dog set, or as standard replacement
K Series Synchro:
How do these compare to the Mfactory (other than the issue with the syncro replacement being much easier)?
I have basically a new Type R trans in my R right now and it's never shifted correctly. I can't power shift at all in the car because it won't even go into gear at high rpms on full boost, and even road racing I need to pause slightly in between shifts for it to be smooth.
We are convinced that the Albins product is the best on the market right now. For your application the 1-4 Synchro set sounds like it would be the best choice. What clutch are you running? Sometimes that will have an effect on how the transmission shifts as well. Another common issue with the OEM transmission is the Shift Change Holder, we offer an upgraded version of that as well.
Albins has design drawings for both synchro and dog sets for the H, but they were done years ago and they want to re-engineer the kit to use the current design layout like the B sets.
This would require a substanial allocation of design time, and thus would require an order of at least 5 sets of either kit to kick things off again.
Yes, they have made 3.50:1 fd in the past for the H and can do custom ratios on request.
As fifth is 1 to 1, I really like the close cogs. 1st is 3:1, so its longer than the OEM 3.3, so I would just need to sit down with a gear calculator to figure it out (Would make the first a bit longer even still which i think would help the heavy car out the hole).
If you could PM me a ballpark for a 1 off, that would be cool. Ill most prob just keep the set I have now, it held together on the dyno after a number of 700-750 pulls, and a very hard session on the street... But I really wasnt to beat the car at the track next year. I think the gearset will be ok, but with 26" slicks the FD wont :O)
