turbo b18b?
just want to know what kind of times and psi you guys are getting. planning on boosting my b18b, but want to hit at least 11's and into the 10's. is this possible on the b18b. and yea i'm gona built up the motor.
Anything is possible with enough money!
I have a moderate goal, i want 15's out of my LS with boost. At the elevation im at, I'll bet it runs like 17 flat. With all luck, I'll get to run it down the 1/4 tonight and find out!
you can get into the 14 easily and maybe even the 13's with the revhard stage two.
If you want to hit tens or elevens, you are going to need some serious work.
Do you got a lot of time and money? At least 10 grand (parts and labor)
sleeved block
pistons
rods
valves
Slicks
60-1 turbo
injectors 770's
Fuel Managment ( hondata, ems. pms. haltec...)
Upgraded ignition systems
Upgarded valve train
LSD
Axels
Im sure your getting the point.....like they said it takes money. 10 secs with turbo is easy if u have to resource.
how much you will boost will depend on your set up....therefor determining your time
[Modified by Cramerox, 5:57 PM 9/20/2002]
pistons
rods
valves
Slicks
60-1 turbo
injectors 770's
LSD
Axels
yea i know what i got to do and that it takes alot of moeny and time, but i' not in no hurry, just want to it get it done right. i'm planning on making it into a drag car only.
CivVtec
Sep 30, 2007 09:32 PM
