Not my night. Snapped head...
I was switching out the shocks tonight. Fronts went great. Moved on to the rear, the shock bolt came out fine, then....
I almost threw up on the spot. What is my best option here?
97 Civic
97 Civic
knock the nut off the other side (the welded on one). Then source a new nut, use anti seize when putting it back together.
if the bolt is still stuck in the lca you could buy new lca, or you can just get a new bushing which is dirt cheap. id recomend energy suspention, but you can always get a replacement bushing for like 10 bucks for the single bushing. .
or you could always try to drill it. good luck
Duh! Thanks, civicsmoke! Should've thought of that. That seems like it would be MUCH easier than drilling/tapping. I should be able to get the bolt out of the LCA if I can get that nut off. I called Honda earlier today to see how much one of those bolts are. $9/bolt....
lol on my gsr every bolt in the lca broke except 1 .... the best way is to break the welded star nut lose then hammer and punch the bolt out or like mentioned press the bushing out ... i replaced everything so i just cut the ear off of my rear struts pulled em out then dropped the whole trailing arm and brought brand news ones for the dealer ... boi was that exspensive they cost like 250 each
Thanks, guys. I guess I must've been lucky thus far, as this is my first one in 10+ years.
The joy continues, as I stripped the allen key trying to remove the top nut! Maybe this is a good excuse to buy an impact wrench. Ha ha.
We did that on my friends car, broke the welded nut got new bolt and nut and everything is fine.
I did the same thing on my shock, i was pissed. What i ended up doing was getting vice grips, and put them on the top of the piston, as close to the top hat as i could.
Yes,you will leave marks on the pistons, however hopefully they are high enough to where it wont hurt anything.
My shocks were already blown so i didnt care.
Well, ended up just cutting the shock. The thing was rusted SOLID.
Still having trouble knocking off that welded nut. Took a mini sledge to it, but to no avail. Any tips?
um best thing for rusted bolts is torch but if you dont have one just remove the whole lca and pull the whole thing off and then cut that nut off the spindle and remove it..
Finally got the welded nut off, thanks to dremel. Just for everyone's info, the nut is tack welded on THREE sides, not two (like I thought). One at the very top and two on the sides (imagine a Mercedes symbol over the nut to visualize the placements). Anyway, got the LCA out and after 2 hours of merciless beatings with a 4lb sledge, I gave up trying to get that rusted/seized bolt out. Trip to Honda this morning and problem solved.
Spent more than I wanted, but this should last me a while. At least until I get some better ones (EK9?).
Once again, thanks everyone, for the inputs.
maynards_ek
21
Jan 31, 2009 07:05 PM
thenick
Apr 10, 2006 08:20 PM
ophdehEEzY
Sep 8, 2003 04:53 PM
