Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
HELP! aftermarket projectors...
Old Oct 22, 2010 | 07:14 PM
h0ndafanat1c's Avatar
Default HELP! aftermarket projectors...
Hey guys, I have an 03 civic ex 4 dr. I installed a set of aftermarket projectors with halos (but havent hooked up the halos). I also got a set of superbright bulbs for the lows and high beams. After a couple months, one side low beam went out, so I left it that way since I wasn't driving at night very much. Then I decided I should just put back the stock bulbs in the low beams, so I did that. Now, the left side low and high beams do not work. And now the light for high beams in the gauge cluster doesnt work...
Does anyone have any ideas? Blown fuse? I just dont know what to do and am thinking of just going back to stock headlights unless I can figure this out.
Old Oct 22, 2010 | 08:56 PM
jdmfreak1992's Avatar
Default Re: HELP! aftermarket projectors...
If I were you I would go back to stock. Check your Headlight Relay in the relay box under the hood its in the very top right corner of the box and bottom right corner. Also just for good measure check the fuses under the dash there might be a blow one.
Old Oct 23, 2010 | 03:17 PM
Hmm, well I guess I gotta start searching for a set of OEM headlights then (since I was stupid and threw them away)
Thanks for the info.
Old Oct 23, 2010 | 06:56 PM
That just my op I don't like the light projectors put off not bright enough for me. But if you like them and they work fine you should keep them. just need to figure out what's not keeping them from coming on.
Old Oct 24, 2010 | 05:46 PM
baller14k's Avatar
i Had a set of projectors and i hated them the light bulbs burn out quick.
If you do buy some headlights do not buy the ones from ebay that are depo! There not fitted properly and they leave a gap between the the fender and bummper of the headlight.
Old Oct 25, 2010 | 07:37 PM
i have the anzo black projectors. i got them from procivic. and i got the recommended bulbs that go with the projectors, but they suck. the cut off sucks. the bulbs suck, the projectors suck.
guess i'll be going back to stock.
Old Oct 25, 2010 | 07:41 PM
woodwardba0526's Avatar
You guys should check out http://www.hidplanet.com/forums/ and http://www.theretrofitsource.com/pro...roducts_id=236.
pr1madona
Honda CR-V & Element
Oct 1, 2016 11:52 AM
meric
11
Dec 26, 2007 01:04 PM
Loco-B
Nov 19, 2007 07:05 PM
stupidsn87654
Lighting
Sep 8, 2007 07:27 PM
Madvillian45
Nov 14, 2006 04:10 PM
