Suspension & Brakes Theory, alignment, spring rates....
would 89-91 civic/crx suspension fit on 95 del sol
Old Oct 22, 2010 | 01:26 PM
whokidd's Avatar
Default would 89-91 civic/crx suspension fit on 95 del sol
Was wondering if 89-91 civic/crx suspension will fit on a 95' del sol. Thanks in advance for the help.
Old Oct 22, 2010 | 04:41 PM
Targa250R's Avatar
be professional
Default Re: would 89-91 civic/crx suspension fit on 95 del sol
Define "suspension." What exactly do you intend to swap? Springs? Dampers? Springs and dampers? Control arms? Knuckles? Trailing arms?
Old Oct 22, 2010 | 05:23 PM
whokidd's Avatar
Well my friend has a cheap set of tein basic coilovers for 89-91 civic/crx. Can those fit my del sol?
Old Oct 22, 2010 | 05:31 PM
Targa250R's Avatar
be professional
You can install them if you use the front lower shock forks from an '88-91 Civic/CRX. The del Sol front lower forks are too large in diameter.
They are shorter overall than the correct coilover assemblies for your vehicle, so you'll gain some damper compression travel but lose some droop travel. It shouldn't be much of a problem as long as you're using stock upper control arms in the front.
Old Oct 25, 2010 | 12:04 AM
whokidd's Avatar
Thank you so much for your help
Old Oct 25, 2010 | 12:21 AM
el crapitan's Avatar
it's the other way around. ef/da struts are taller than dc/eg. specifically the rear
Old Oct 25, 2010 | 07:19 AM
Targa250R's Avatar
be professional
DA rear dampers are NOT the same as EF/ED rear dampers. DA rear dampers have longer bodies and the spring perch is mounted lower on the body so the free length of the spring is also longer.
Also, damper body length does not necessarily correlate with full extension length.
Old Oct 25, 2010 | 06:33 PM
ahh i see. my apologies and thanks for informing
Old Oct 25, 2010 | 11:46 PM
whokidd's Avatar
So, it won't work then?
Old Oct 26, 2010 | 03:45 AM
Targa250R's Avatar
be professional
If you have the EF/ED front lower mounting forks, it works - just not as ideally as the correct parts.
Old Oct 29, 2010 | 07:56 PM
whokidd's Avatar
^^^thanks
Old Dec 1, 2010 | 09:31 AM
Cresendo's Avatar
I have the same question will my Crx rear struts fit my 93 del sol
Old Dec 1, 2010 | 09:42 AM
Tyson's Avatar
x2 everything targa said.
why are you asking the same question if its already been answered?
Old Dec 1, 2010 | 09:55 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
answered question has been answered.
1PT-SICK
May 18, 2007 10:23 PM
Delsol0705
Jul 28, 2006 08:12 PM
DaveyDelSol
Jul 24, 2006 04:06 PM
2K4K20
Aug 14, 2005 05:47 PM
cpizzy
Dec 20, 2003 08:02 PM
