Hesitation problems
Last week i got very crummy gas mileage, i normally get 350-360 miles to the tank, last week it was a tad under 200 miles, this week when i was driving my car was hesitating and it felt like the whole car would thrust forward then stop instantly.
I pulled down the carpet and found a code 16 (injector) so i went ahead pulled both injectors (dpfi) cleaned them and then put it back together, didn't realize it but the o-rings needed to be replaced.
Drove the car noticed that i was leaking some fuel so I replaced the O-Rings.
Now its still doing the same problem with the hesitation no CEL's
This morning it drove to work fine, i stopped at the store, turned the car off, when i came back outside and turned it back on the idle surged approx 5 times then the car had no power at all and started to die, i tried to rev it and it did nothing.
In the last 3 months I've replaced the Ignition Control Module, Fuel Filter, and Main relay.
A bit more info on the car
88 Civic DX
Stock D15b2 Motor
DPFI
5 Speed
aftermarket Intake/Exhaust
Thanks
88 Civic DX
Stock D15b2 Motor
DPFI
5 Speed
Thanks
moacsupreme
Oct 19, 2014 02:15 PM
