need some help
Old Oct 22, 2010 | 07:32 AM
jsinher3's Avatar
Default need some help
i have a 91 honda civic dx i just rencently brought. the car was stored for awhile and soo the enginebay was filthy so i decided to clean it wit some engine degreaser and a pressured water hose. now before i started to spray the car down i made sure to cover the dizzy, alternator, fusebox and after i went with a rag to try to dry everything on the bay it started up with no problem. now the next morning i turned the car on with no problem but out of nowhere the car just shut off on me and so i didnt think much of it until later that night i was driving and it shut off again and again this morning when i went to start it did the same and again when i was driving to work..
Old Oct 22, 2010 | 11:41 AM
sobosscrx's Avatar
Default Re: need some help
Does the check engine light come on? If it does what code is it showing?
Old Oct 22, 2010 | 09:10 PM
chansta's Avatar
yeah no matter what anyone says never wash down the engine bay... you're just leaving yourself open to electrical problems.
Old Oct 22, 2010 | 10:56 PM
Icon_Ed6's Avatar
X2, give every1 a place to start figuring it out
Old Oct 23, 2010 | 07:40 PM
jsinher3's Avatar
no CEL but today i check the the sparkplugs to see if they had any kind of water or degreaser on it and it seems that the were somewhat damp with a kind of oil or grease so i dried them up and also tried to dry the spark plug cylenders* and it seemed to kind of work. while driving i can see the rmp gague moving up and down by itself and later on in the day i tried to start it and it started i heard something schreech and the rmp go up and then die i tried it again and it did the same thing so the 3rd time i gave it gas and it schreech but it stayed on..and also to it seems to be missfiring but im not sure seeing that i dont have a complete muffler and it also bogs at time the rmp goes a lilttle crazy...
Old Oct 23, 2010 | 07:43 PM
jsinher3's Avatar
also could it be that the degreaser/ wd40 might have messed with the timing belt? and its not on time
Old Oct 23, 2010 | 08:13 PM
90 Si Hatch's Avatar
i have washed my engine bay many times with different cleaners and never had any problems.... BUT i always covered my distributor & air filter with a bag and tape it really tight...
Old Oct 24, 2010 | 07:55 AM
jsinher3's Avatar
can anyone please give me any suggestions
Old Oct 24, 2010 | 09:48 AM
asianflava's Avatar
Basic troubleshooting; break it down to it's most basic parts. What do you need for your engine to run? Air, Fuel & Spark. Check those then go into more detail when you find a problem with one of them.
The usual suspects
Air: Not usually a problem blocked intake
Fuel: Main relay, Clogged line/filter, Bad pump
Spark: Igniter, Plugs, Dist
nixcite
Jul 26, 2008 11:03 AM
Mandeep
Jul 17, 2005 11:33 PM
Notahon DUH
Aug 12, 2004 09:48 AM
