d16a6 low compression.
Old Oct 21, 2010 | 03:50 PM
nopain20's Avatar
Default d16a6 low compression.
k, i bought a d16a6 with the head n block unbolted. After sitting in the garage for 2months i brought it to a shop to install new Y8 head gasket, new timing belt. Once got the motor back we took out my stock 1990 hf motor plus the tranny and drop the d16a6 with the d16a6 tranny in. Got everthing installed. Motor crank but wouldn't start. Got fuel and spark so i did a do compression test. Came out to be 20 115 110 10. What should i do? Need motor to ran.
Old Oct 21, 2010 | 03:59 PM
tyked15's Avatar
Default Re: d16a6 low compression.
holy hell low compression...think you need a new set of piston rings there guy
BiG ChOr!Zo's Avatar
those are pretty low numbers for a compression test...!!!
Old Oct 21, 2010 | 08:27 PM
nopain20's Avatar
so is that why i can't start my motor? is there anything to fix it?
Old Oct 22, 2010 | 07:41 AM
Cameron R's Avatar
Wow, talk about a waste of effort! What made you think the short block was good? Nothing to do here but rebuild the engine...
Old Oct 23, 2010 | 08:19 PM
nopain20's Avatar
I'll see what i can do. Thank though.
Old Oct 23, 2010 | 09:30 PM
ef_89's Avatar
i would get a d16a6 head gasket first, i would think the y8 gasket would be different
Old Oct 23, 2010 | 09:50 PM
DCRB's Avatar
nope y8 head gasket works just fine. i used one. only difference is mls vs graphite
Old Oct 27, 2010 | 04:25 PM
nopain20's Avatar
k, figure out the problem. i though timing was right but it was off. now got the timing fix car is running and start up every time.
Texas4door
Dec 5, 2011 08:36 AM
jdmhonda123
Dec 1, 2010 10:28 PM
NACvicSi
10
Oct 19, 2005 01:31 PM
t3hatch
Nov 8, 2004 09:49 AM
