97 civic hb rear disc conv help!
So i need just a straight up answer so to say for what i will need, i have been digging through threads trying to find answers but this will just be easier. i picked up rotors, pads, Si calipers(front & rear). What else do i need to complete rear conversion. I have been told i dont need the lower arms but i will need new upper arms? i keep reading blips about prop valve? I have been told i need a knuckle/hub for each side? An si e brake line? All i have are the calipers pads and rotors. please someone who has done this on this car give me an answer so i know what to and what to not buy. Thanks for input.
you will need the spindle from an SI if your not gonna get the whole trailing arm setup. the knuckle/hub is for the front either ex/si
http://www.b20vtec.com/forums/suspen...pplicable.html
awsome write up
awsome write up
You can use your drum rear trailing arms and this spindle kit: http://www.scarebird.com/index.php?id=42
just_bn_me83
13
Oct 24, 2010 07:28 PM
cprlover
Jul 10, 2009 06:13 PM
