OT: Piston to valve clearance, thoughts on this before i clay the motor
b20b bottom end, del sol head milled 30 thousandths and stock itr valves with toda spec b cams and valvetrain. stock oem b20 head gasket. you think there will be any clearance issues with this? gonna clay it but would like to know what i am getting into ahead of time. thanks.
yes, you may have issues only because you have those b20 pistons ... also make sure you test clay with both gears advanced to make up for cam retard.
Greg
Greg
oops, pistons are endyn rollerwaves 12:1 compresssion. will this make a difference? how far would i have to advance the gears to make up for the milling? isnt the ratio like 0.012 milled = 1 degree retard? so i would be starting off at like ~3 degree retarded correct?
[Modified by CART fan, 4:56 PM 9/20/2002]
If your block hasn't been decked(milled) at all and you head has been milled .030, you should be fine with the rollerwaves.
stratedrm
Jul 18, 2009 06:02 AM
hotintegranights
Apr 7, 2004 01:38 PM
Shark Tank
Sep 21, 2002 11:20 PM
