Piston to valve clearance, thoughts on this before i clay the motor
Old Sep 20, 2002 | 09:19 AM
Shark Tank's Avatar
Default Piston to valve clearance, thoughts on this before i clay the motor
b20b bottom end, del sol head milled 30 thousandths and stock itr valves with toda spec b cams and valvetrain. stock oem b20 head gasket. you think there will be any clearance issues with this? gonna clay it but would like to know what i am getting into ahead of time. thanks.
Old Sep 20, 2002 | 12:57 PM
Shark Tank's Avatar
Default Re: Piston to valve clearance, thoughts on this before i clay the motor (CART fan)
oops, pistons are endyn rollerwaves 12:1 compresssion. will this make a difference? how far would i have to advance the gears to make up for the milling? isnt the ratio like 0.012 milled = 1 degree retard? so i would be starting off at like ~3 degree retarded correct?
Old Sep 20, 2002 | 01:41 PM
Rocket's Avatar
You should be cool. Just make sure to check clearances with the high lobe engaged.
We run bigger cams and advanced the intake about 6 degrees with no problems.
Old Sep 20, 2002 | 03:22 PM
tinkerbell's Avatar
Default Re: Piston to valve clearance, thoughts on this before i clay the motor (Rocket)
on STOCK B20B pistons?!?!
did you clay it?
t..
Old Sep 20, 2002 | 03:41 PM
Rocket's Avatar
Default Re: Piston to valve clearance, thoughts on this before i clay the motor (tinkerbell)
He's got the Endyn pistons.
Old Sep 21, 2002 | 06:00 PM
tinkerbell's Avatar
OK
t..
Old Sep 21, 2002 | 11:20 PM
miller's Avatar
should be alright. just clay away, that is the only way to really know.
gutted-dx
Sep 1, 2009 02:28 PM
gs1gsr
Jan 13, 2008 09:20 AM
b20powereDA
Jun 21, 2007 04:40 PM
turbociv
13
Sep 24, 2003 12:57 PM
Shark Tank
Sep 20, 2002 01:13 PM
