power help
Old Oct 20, 2010 | 08:23 PM
scottypippen147's Avatar
Default power help
i have a 90 accord and i put a f23a1 out of a 98 accord motor in it and it is running off the stock f22 ecu and also the f22 dizzy and egr valve. i expected the motor to be more powerful than the last one but it is actually really slow and if u full throttle it it goes nowhere and pretty much anything after 4000rpm is pointless. the only code on the ecu is the egr valve but i dont think that would affect that much power. is there any other thing i should check or consider as to what would make it have such a power loss?
Old Oct 21, 2010 | 03:03 AM
davey5300's Avatar
Default Re: power help
change to a OBD 1 F22B1 ECU and wire up the vtec solenoid and vtec pressure switch and use the F23 Distributer
Old Oct 21, 2010 | 09:42 AM
well the f23 distributor is wayy different than a obd1 dizzy..is there a certain way i could wire it in to make it work?
Old Oct 21, 2010 | 09:46 AM
chikin pickle's Avatar
Short answer yes, long answer doubtful.
Go get a chipped obd1 ECU and get it programmed with an F23 basemap.
Old Oct 21, 2010 | 09:52 AM
welll that sounds expensive lol and idk who could make one for me anyways so i would probably more likely go with the f22b1 ecu. well as long as it will work a bit better. but is it ok to use the f22 dizzy?
Old Oct 21, 2010 | 10:18 AM
HondaPartsHero's Avatar
Technical Hero
yeah you need to run the correct ECU especially to activate VTEC which is right around 3800 RPMs.
Old Oct 21, 2010 | 11:39 AM
GhostAccord's Avatar
The F23 is rated for an extra 15-20 Hp over the F22A*. That's not really a huge, seat of the pants, power gain there. You will require the proper F23 ECU or equivalent to see that power gain. Equivalent being a chipped and tuned OBD1 ECU or worst case an OBD1 F22B1 ECU.
Old Oct 21, 2010 | 12:14 PM
davey5300's Avatar
oh my bad did I say use the F23 distributer?? I meant if you use the F22B1 distributer if you use an OBD 1 ECU (I forgot that the F23 was OBD 2)
garrett2115
Mar 2, 2019 08:42 AM
Rat Rod
Nov 15, 2010 05:30 PM
TMC_EF
Jan 24, 2009 05:12 AM
purpl7duece
Oct 9, 2003 10:09 AM
RockDawg_GSR
Feb 24, 2003 09:12 AM
