Crank, wont start
Old Oct 20, 2010 | 05:15 PM
Hondatherdm's Avatar
Default Crank, wont start
well heres my question i have 96 civic that i did motor swap, anyways i started it couple of times then when i went to start it all i get is cranking but no start, i listen to fuel pump, no prime. So i look at the wiring diagram and i gave 12v to grn/yel wire (i was doing that at PGM-Fi relay) and pump primed, so that part is good, pcm is good, pgm relay is good, i tested all of them in different car, fuses good. heres what i get with ignition "ON" from all the wires at PGM-Fi relay:
grn/yel - 12v
blu/wht - 12v (while cranking)
wht/blk - 12v
yel/blk - 12v
yel/grn(to pcm) - 12v
yel/grn (to pump) 0v
blk - 0v
If you can throw some ideas, im kinda stuck
Old Oct 29, 2010 | 02:26 PM
Default Re: Crank, wont start
For those of you cares yel/blk was 1v where it needs to be 12v, that wire comes from ecu and theres a junction behind blower motor and there was a bad connection/lots of resistance
Old Dec 11, 2010 | 11:49 AM
taylor94's Avatar
did you check the main relay it will be by your left knee if you siting in the driver seat thay go out all the time
RiPe14yoU
Jun 10, 2017 06:17 PM
kaz norvaisas
Jun 30, 2015 03:41 AM
raverx3m
Sep 16, 2011 11:09 PM
grkblood13
Aug 28, 2008 04:22 PM
dizzyroc88
12
Mar 22, 2007 01:16 PM
