Anyone with a Inner Tie rod DIYon the EG? Please post NEED YOUR HELP!
pretty simple really.... lift the vehicle, remove the wheels, break the lock nuts loose on the tie rod, the remove the cotter pins from the outer tie rods, then the outer tie rod nuts, the use a hammer n hit the spindle to free up the outer tie rod. remove the outer tie rods. then you will remove the lock nuts off the inner tie rods, remove the boot, and unscrew the inner tie rod from the rack.... installation is opposite from removal.... dont for get to take it and have an alignment done!
