B18c1 fully built
I am selling my fully built b18c1 engine. This is an obd1 motor and will come with an unmolested p75 obd1 ecu. There were originally 176xxx miles on the motor currently there are 0 (none whatsoever) miles on this engine since the build. I have receipts for this also, and the engine is still in the plastic. The build was done by Kaley Motor Service Inc out of South Bend Indiana.
B18c1
SRP Forged 9:1 Pistons w/ rings
Eagle forged rods
All gaskets and seals have been replaced (lower gasket set, upper gasket set, front main seal, rear main seal)
Block guard
Rod bearings
Thrust washers
ARP Head studs
Main Studs
Waterpump
Timing belt
New freeze plugs
Balanced and blue printed
Port and polish head and valve job
Block has been decked and head has been milled
The motor is fully assembled and ready to drop in. It was built to be boosted and I had plans of running an HX35 turbo on it at 22lbs, should put the motor at about 550whp with the right injectors and tune.
I have over 4500 invested but need the money right now. Looking to get 4000 obo. I would be open to any offers...worst I can say is no.
Text me at (27O)317-5962
I can deliver this motor to the surrounding states if the deal is good. Thanks for looking.
B18c1
Eagle forged rods
Block guard
Rod bearings
Thrust washers
ARP Head studs
Main Studs
Waterpump
Timing belt
New freeze plugs
