Suspension & Brakes Theory, alignment, spring rates....
Help! GC and konis yellow set up trouble.
Old Oct 20, 2010 | 09:16 AM
JENNY_EG6's Avatar
Default Help! GC and konis yellow set up trouble.
Please excuse my terminology, I really don't know the right term to explain the problems, but hopefully you guys will know what I mean. I'm running on Konis yellow and ground control the spring rate is 350 front 360 back? front has 2 top hats. The car is some what dumped. The car rides a bit bouncy when i have it a bit toward the stiff side, but that isn't really what concerns me, just that when the car drive through a pot hole it would go "BAM" like I"m bottoming out.
Those of you who've played around enough with your shocks settings might be able to help me, its really frustrating and this is on an 96 Integra coupe
Old Oct 20, 2010 | 09:49 AM
STOCK_SOHC_DX's Avatar
Default Re: Help! GC and konis yellow set up trouble.
If your car is dumped you most likely need stiffer rates. I would also double check your bump stops and make sure they are trimmed short enough.
Old Oct 20, 2010 | 10:17 AM
JENNY_EG6's Avatar
I'll double check the bump stop
Old Oct 20, 2010 | 10:25 AM
JENNY_EG6's Avatar
yea you're right I forgot to trim the front bump stops in half maybe thats the reason for the sounds
Old Oct 20, 2010 | 11:19 AM
Drive 4 fun's Avatar
A hard "bam" may be hitting the bump stop as suggested, and half the bump stop may still hit, with less padding. Higher spring rate or raise the car a little.
Old Oct 20, 2010 | 11:23 AM
JENNY_EG6's Avatar
yea i'll try fixing the bump stop problem, but I like it being slammed if I have to deal wit the "BAM" I guess I'll just have to deal wit it.
Old Oct 20, 2010 | 12:05 PM
racebum's Avatar
get stiffer springs or raise the car to a non cholo ride height. something like 550/500 would help you out quite a bit if you actually like driving a spark tosser
Old Oct 20, 2010 | 04:59 PM
Jenkinsal2's Avatar
stiffer springs! dont cut your bumpstops if you dont know how to or where to. If you cut too much off you can ruin the dampers by bottoming them out.
Old Oct 20, 2010 | 09:04 PM
707the89fu's Avatar
yeah tell that to your header and oil pan Fool LOL
Old Oct 21, 2010 | 01:36 PM
98civdx's Avatar
Master Detailer
Are you sure it isn't the uca's hittng the shock towers?
Old Oct 21, 2010 | 02:03 PM
kristo's Avatar
Loved
Visiting HT makes one learn someting new every time
Old Oct 21, 2010 | 06:35 PM
BiG ChOr!Zo's Avatar
Old Oct 24, 2010 | 12:30 PM
JENNY_EG6's Avatar
My header n oil pan isnt hittin anything, not a single scratch on it...
Old Oct 24, 2010 | 12:59 PM
ej1 rep's Avatar
cut dem bump stops dood, also usually you have stiffer rates in the front than in the back.
ramboPandA
Suspension & Brakes
Mar 29, 2014 03:37 PM
mynameizstitch
Suspension & Brakes
23
Jul 31, 2012 02:03 PM
CRXguy_88
18
Sep 2, 2011 08:39 PM
ThatOneGuy3131
Jun 29, 2010 01:56 PM
civexspeedy
Sep 1, 2007 09:10 AM
