WTB: Complete MPFI for D15b2
I have a full complete d16a6 intake with everything on it I have a d16a6 dizzy and a pm6 ecu and a resistor box with pig tale so if yoy follow the DIY write up I have all needed parts pm me or text me 8608660309
I have it all A6 Manifold complete missing injectors will include a z6 rail.. you can also find some obd1 injectors that way you dont need a resistor box.. Then i have a SI dizzy distributor works.. PM6 ECU resistor boxes.. everything you need.. I can find the diagram how to do it its easy.. and also can get injector clips or you can when you find the injectors.. Just use your Dual Point harneses..
