91 CRX DX Disc Brake Conversion using Del Sol parts?
Hello I searched and just wanted to clarify on this rear disc swap. I have read that the trailing arms on my 91 CRX DX and my 95 Del Sol are the same so I just have to use the hub assembly, calipers, discs, and DA e-brake cables. Please clarify if I am missing something with this swap.
Thanks, Pat
Thanks, Pat
wrong. you need crx si (91) rear disk brake cables. all others will drag. you may be able to use the del sol brake cables. when i used this set up from a del sol onto a HB, the cables were way too short. and the DA cables werer too long on my car and they dragged on the ground. best thing to do is get the CRX Si Rear disk brake cables.
424racer
15
Apr 25, 2010 07:48 PM
310HPS2k
10
Mar 13, 2009 05:45 PM
go2sleep
Jun 15, 2004 10:51 PM
