H22: Mahle Rings on OEM Pistons?
Old Oct 19, 2010 | 10:30 PM
Lude@Heart's Avatar
Default H22: Mahle Rings on OEM Pistons?
Seeing how Mahle gold series pistons and rings work with our FRM liners and the Mahle rings are much cheaper than the OEM honda rings, does anyone kno if its possible to use their rings on a factory piston? I'm doing a Type-S Piston rebuild.
Issues that come to mind are ring thickness for example.
Input please.
Thanks
Mario
Old Oct 20, 2010 | 12:06 AM
bambam's Avatar
Default Re: H22: Mahle Rings on OEM Pistons?
Not sure....but have you looked into hastings? GREAT rings. And the fact that they're not expensive is just a plus.
Old Oct 20, 2010 | 05:29 AM
Uncle Dave's Avatar
After years of using Hastings I now have started to use Mahle rings for my OEM style builds and they are cheaper in Australia than Hastings.
Old Oct 20, 2010 | 08:23 AM
Lude@Heart's Avatar
Hastings rings work great for Iron sleeves. AFAIK you must use FRM compatible rings.
Uncle Dave, are you talking about B series builds or H22 FRM builds.
Old Oct 20, 2010 | 12:33 PM
Uncle Dave's Avatar
I have done 1 FRM H22 build using the Mahle rings 12 or more months ago car is running fine,the local supplier said to me they where for the FRM engine.Hastings are still a great ring set and either one will serve you well.
Old Oct 20, 2010 | 02:55 PM
Lude@Heart's Avatar
so the Mahle rings do fit on a Factory piston is what your saying. And do you recall the part number for the rings?
Old Oct 21, 2010 | 01:07 PM
SiR_Chris's Avatar
In a similar vein, but the opposite way round. I have brand new OEM H22 rings, and Mahle pistons lol. Can I use them that way round?!
Old Oct 23, 2010 | 01:48 AM
Lude@Heart's Avatar
i would assume so because when u look at any Mahle description they mention how the ring locations are OEM fit
Blake St.romain
Aug 26, 2018 08:34 PM
turbo boost
Oct 27, 2014 11:09 PM
boosted93h22lude
Apr 18, 2007 05:55 PM
quik1
Jun 19, 2004 06:33 PM
