Car locks up when backing up in reverse and I push the brakes
Old Oct 19, 2010 | 05:35 PM
dc2LS's Avatar
Default Car locks up when backing up in reverse and I push the brakes
Well i just installed an exedy stage 1 clutch on my integra.It was running fine for a few days but today when i was backing out in reverse as i pressed the brakes it locked up .But if I back up and use my E brake it wont lock up only whe going in reverse and I aplpy the brake.What could it be? I know i need new brakes but i dont think there that bad it also started raining today .Any help will be appreciated
Old Oct 19, 2010 | 05:46 PM
1998GsRIntegra's Avatar
Default Re: Car locks up when backing up in reverse and I push the brakes
Exactly what is locking up? Your post is a little vague in places.
Old Oct 19, 2010 | 07:32 PM
koss1229's Avatar
How about you find a little hill and back up without any help of transmission. Hit the brakes and see if it "locks up" the same way.
Old Oct 19, 2010 | 08:10 PM
dc2LS's Avatar
oKAY so i rolled it down my driveway in neautral and hit the brakes and my brakes locked up .Im glad its not the tranny but wats causing this
Old Oct 19, 2010 | 09:17 PM
koss1229's Avatar
So your brakes are getting jammed somehow. Lose pads maybe? Since it never happens with an E-brake, then you can eliminate the rear side. Check your front pads, something is wrong there. Good luck
Old Oct 20, 2010 | 07:24 AM
vtecdc4's Avatar
when my brakes kept locking up it was because of the brake master cylinder. i would get it checked out.
Old Oct 20, 2010 | 06:25 PM
dc2LS's Avatar
You were right on the money the caliper was loose.Thanks alot guys
black94boost
Oct 27, 2006 11:05 AM
97dc2
May 14, 2006 08:23 PM
See Are X
Jun 1, 2003 02:51 PM
denieone
Jun 24, 2002 02:17 PM
