PGMFI Breakthrough: OBD1 Datalogging on stock ECUs
Old Sep 20, 2002 | 07:57 AM
blundar's Avatar
Default PGMFI Breakthrough: OBD1 Datalogging on stock ECUs
Well, the PGMFI project has had a major breakthrough (THANKS Doc!) in the field of datalogging.
A stock EDM P30 running a modified program now speaks a very simple 9600 baud serial commuications language allowing all values in the ECUs memory space to be read/wrote to. A $20 serial interface box is all that is needed, hardware wise. This advance doesn't sound like much initially but realize all sensors and all values used for fuel/timing routines live in RAM. Add in that Vtec activation and probably injectors/timing control are implemented as memory-mapped ports ...
What we really need now is someone with lots of free time who is a very good VB, VisC++, etc. programmer that can write Windows/Mac/Linux applications based around this simple protocol for engine monitoring and management.
See http://pgmfi.crx-forum.org/ if you think you can help, or are just curious. More about this and the code in question can be found in the OBD1 forum. Beware: the code might not work in USDM ECUs w/o modification.
Peace
-Dave
Old Sep 21, 2002 | 08:25 AM
TimoneX's Avatar
New User
Default Re: PGMFI Breakthrough: OBD1 Datalogging on stock ECUs (blundar)
Wow that is kewl. Isn't the P30 for the Del Sol though? Think it'll work for all the OBDIs? P28s and P72s are SO much more common. Good work!
fusca_power
Oct 19, 2014 08:20 PM
jeffrox626
Feb 27, 2011 06:58 PM
DEPintheCurve
Sep 26, 2008 04:07 AM
Topdawgg
Mar 14, 2007 03:02 PM
