help: ICM / Igniter Questions and problems
Hi guys,
Long story short, I purchased the wrong igniter (Electric Systems brand, Honda #06302-pt2-000, new from a forum so I cant return it) and now am hesitant to spend another 165 dollars to get the one specific to my distributor (Hitachi brand, Honda #30120-p06-005).
So I was wondering if any of you guys knew of the difference between the various igniters that Honda uses (NEC, Hitachi, OKI, etc). My research says that the igniter is essentially a switch that magnifies amperage for the coil, no? Is there no difference besides mounting holes?
If it is just the mounting holes, can I use the mounting bracket (heat sink) from an accord/prelude: Amazon.com: OES Genuine Igniter Heat Sink for select Honda Accord/Prelude models: Automotive
to install the Electric Systems brand igniter into my distributor?
Has anyone done this?
The car is a 1996 Civic Ex ( D16y8 )
Any help is appreciated, aka information about the igniters or a known reputable source to get a new hitachi igniter for less than 165.
i've used hitachi and OKI igniters interchangeably before. They just have slightly different mounting brackets. Work the same though.
^ Where have you gotten the mounting brackets? Just off a spare distributor?
Did you notice any difference in spark or any other effects?
Nope, only that I seem to have seen more Hitachi igniters go bad than OKI.
Alright, it looks like I will just run the electric systems one instead of the hitachi one since I got a different mounting bracket.
Thanks for your help 94EG8
