D16Z6 Low Rev Limit and No VTEC Kicking
Old Oct 19, 2010 | 09:20 AM
94EJ1CivciSi's Avatar
Icon2 D16Z6 Low Rev Limit and No VTEC Kicking
I've got a 94 Civic EX with a D16Z6 and I can't rev past 5.5K RPM and I know that the VTEC kicks around 4800 RPM but the VTEC doesn't kick in. What's causing this to happen? Do I need a new dizzy and VTEC solenoid and/or gasket? Let me know what you think this is. Cause I feel like I'm losing a lot of power cause of this.
Old Oct 19, 2010 | 09:32 AM
94EG8's Avatar
Seagull Management
Default Re: D16Z6 Low Rev Limit and No VTEC Kicking
CEL on?
Old Oct 19, 2010 | 09:35 AM
speedooo's Avatar
you probably have a check engine light and your ecu is preventing you from beating on the motor to prevent damage
Old Oct 19, 2010 | 09:56 AM
EJeff8's Avatar
Yes, if the computer thinks it's that serious of a problem, it knows not to add hp to an already bad problem, or so it thinks.
Old Oct 19, 2010 | 10:14 AM
ej1916's Avatar
Not sure about your RPM problem but the Vtec not kicking in issue can be caused by the CEL if its on, low oil, or it could be the Vtec solenoid. I had a problem with my Vtec and it turned out to be the solenoid. Oh and your engine has to be warmed up a bit for vtec to kick in I believe.
HondacivDX
Feb 19, 2012 06:52 PM
SpeedGyrl
Mar 16, 2003 04:23 PM
E dwinbon G
Jan 11, 2003 02:33 AM
