with cruise on car is constantly surging
Old Oct 19, 2010 | 05:38 AM
fcluddington's Avatar
Default with cruise on car is constantly surging
I have about 500 miles on a boosted b18c on e85. when i set cruise at 62mph i get this surge it nots real bad but i would like to tune it out. it happens at 3300rpm appr. 292mbar surges to 400 plus on the map sensor. eng temp 172. I thought it was fuel cut. because it never happened pulling up a hill. only on flat land. Everything else is perfect.
Old Oct 19, 2010 | 06:30 AM
mtber's Avatar
Default Re: with cruise on car is constantly surging
Do you have a wideband oxygen sensor installed in the vehicle to monitor your lamda?
If not, get one....
Old Oct 19, 2010 | 01:05 PM
yes there is a inovate wb. i was actually trying to tune it out. i tryed on the low cam fuel tables no help and i tryed on the ignition table. I am trying to decide if its a car issue or a tune issue. as long as their is a slight load on car like going up a slight hill it will not do it. only when on flat ground. also i am not in closed loop. using Neptune. tuning by self. (novice)
Old Oct 19, 2010 | 01:28 PM
2k.civic.si's Avatar
"292mbar surges to 400 plus on the map sensor"
i haven't looked in awhile but i know the cruise control system requires vacuum...i wonder if the cruise control system itself is causing a vacuum leak from something faulty in it?
Old Oct 20, 2010 | 04:37 AM
I never thought about that but that sure makes sense i will check it out. Thanks much
Veggie Man
Sep 25, 2012 02:49 PM
stangbanger2112
Jan 1, 2012 08:15 PM
Tjabo
May 15, 2011 01:29 PM
AR_motorsports
Honda Civic (2001 - 2005)
Aug 28, 2007 09:15 AM
tigueremalo
May 2, 2006 02:58 PM
