When i'm in neutral - not braking - I can hear the pads rubbing on the rotors wtf?
Old Sep 20, 2002 | 06:58 AM
Alexander's Avatar
Default When i'm in neutral - not braking - I can hear the pads rubbing on the rotors wtf?
Hey guys - when i'm driving by a wall or something that amplifies the sound of my car (engine, brakes etc) - and i'm not even in gear or braking, it sounds like my pads are ever-so slightly rubbing the rotors - kind of like a hissing sound, medium pitched.
My pads are fine - not worn down, but I KNOW my rotors are warped (bad shaking under braking) due to the car not being driven for a year and the sudden change of driver styles.
Anyone have any insight on this?
///Alex
Old Sep 20, 2002 | 08:02 AM
martini's Avatar
Default Re: When i'm in neutral - not braking - I can hear the pads rubbing on the rotors wtf? (AVD23)
on most cars, the pads will rub on the rotors when not braking.
but if they are rubbing too much, maybe that's why the rotors are warped.
Old Sep 20, 2002 | 12:20 PM
X2BOARD's Avatar
Default Re: When i'm in neutral - not braking - I can hear the pads rubbing on the rotors wtf? (martini)
Sounds like the wear indicator on the pad is scraping the rotor. If the pad is very worn, this can happen even when not on the brakes. Check your pads.
X2
Old Sep 20, 2002 | 07:53 PM
3rdGteg's Avatar
Default Re: When i'm in neutral - not braking - I can hear the pads rubbing on the rotors wtf? (X2BOARD)
If your pads are cool and it's not the indicator from the pads, it's gotta be time to change out them rotors; u said they were warp anyways--take care of that and see how they go because mine was doing the same thing w/ messed up rotors (they were very thin--cannot resurface) and now it's gone.
Old Sep 20, 2002 | 07:59 PM
LSVTEC96HB's Avatar
Default Re: When i'm in neutral - not braking - I can hear the pads rubbing on the rotors wtf? (3rdGteg)
pull the calipers off and make sure they slide freely back and forth, sometimes the grease can dry up and they will bind.
globy123
Sep 28, 2009 01:13 PM
NuRon
Mar 10, 2008 05:51 PM
sony224422
Aug 13, 2006 04:30 PM
H2290
10
Jul 28, 2006 01:56 PM
Trellis
Mar 12, 2003 04:50 PM
