NEW Fuel pump buzzing noise inside the car?
i replaced the fuel pump in my car to a brand new one of the same matching quailty and model.
my gas mileage is doing terrible here are the symptoms
1.sometimes** i will have a lead foot and the rmps will go above 3k
2.the new fuel pump makes the buzzing noise (my girlfriend described it: sort of like a bee buzzing)
does anyone have any idea why my car is eating up soooo much gas ?
i have a 94 civic ex coupe
10 gal tank
i had to replace the head gasket and water pump because of over heating
thanks for anything !
10 gal tank
fuel pumps do that, be happy its stock and not a walbro as they are super loud. have you done a recent tune up? if not it might be about time if your getting that horrible of fuel milage.
10 gal tank
10 gal tank
Thanks for the reply!
the type of fuel pump is "master parts division E8338H " i bought it on ebay and it said is compatable with my make and model is this a good model for my civic?
and yes thats exacly what happens to mine at a low RPM with the radio down you can hear it
does that mean its dumping too much fuel into the cylnders?
i wired it up fine i think i will try to check the volts
You may have purchased a bum fuel pump or the wrong one for your car. Did you also replace the fuel filter?
As mentioned, also do an ignition system tune up (plugs, wires, cap, rotor, ignition timing) to solve the low gas mileage issue.
76 camaro car
Sep 23, 2015 02:00 PM
1320whtrex
Jul 31, 2009 05:15 PM
trooper0641
24
Dec 12, 2004 10:09 PM
