EG Si Cluster - temp and gas gauges don't work - Is it possible to repair?
Is it possible to repair a cluster?
I have a cluster and the problem is that the gas milage and the temperature doesn't work. Is it possible to fix that or i just have to get another cluster?
clusters for egs are dirt cheap.
so when its cheap people 99% if tge time replace them.
but if you are good at micro soldering and desoldering you could find where there is burt resistors or compacitors and replace them
ric rabies- Thanks i'll check it out.
ronj@ht- honestly i dont know how to fix the gauges n i'm not sure if the wires are bad or not. but i do see some burnt resistor's.
MTarry
11
Jan 15, 2013 06:46 PM
Yoitshector
Sep 21, 2011 05:19 PM
JDM_WHR
10
Jun 7, 2010 08:50 AM
