A *DIFFERENT* DC2/EK/EG/Del Sol front end conversion thread
Old Oct 18, 2010 | 03:01 AM
Player_One's Avatar
Icon2 A *DIFFERENT* DC2/EK/EG/Del Sol front end conversion thread
First of all, I have no plans on doing a front end conversion. I am however asking questions of those that have done it as my Del Sol has some frame rail damage. I'd like to know how compatible frame rails are and so on between different models.
Also, this is a test of how many people actually read and respond with stupid comments like "don't do it ricer!!!".
Background info for why I'm interested...
My Del Sol is K-series swapped and one thing I hated with my stock passenger frame rail was cutting off the OEM engine mount bracket. It's not required on the EK as the K-series mounts bolt right on to that chassis. Also, the welded on EG engine mount bracket doesn't look as clean as the EK's engine mount.
I'd also like to know if a stock EG/DC2 strut tower will properly integrate with the EK's frame rail as the EG/DC2 upper control arm bolts on differently compared to the EK strut tower. I know the EG/DC2 subframe can be swapped into the EK's so I figure that part should be okay.
Anyway, I'm just looking for people with experience doing the front end conversions to figure out if this frame rail swap will work. Pretty much wondering if all the fenders have the same bolt spacing and if all the frame rails are the same length.
Oh well, I guess I'm going to do more research and look through tons more threads with broken pics.
Old Oct 18, 2010 | 04:53 AM
[ej]Jonathan's Avatar
Lord of the idiots
Default Re: A *DIFFERENT* DC2/EK/EG/Del Sol front end conversion thread
dont do it ricer
Old Oct 18, 2010 | 05:44 AM
markspan6243's Avatar
Flattery Will Get You Everywhere
thats stupid as.....well you insert your choice of words there. just bolt in the k-swap bracket like the other 1000 other people that do k swaps
Old Oct 18, 2010 | 06:57 AM
paperorplastic's Avatar
wait am I reading this right? instead of a cut frame rail mount, you would rather cut and weld different frame rails?
Old Oct 18, 2010 | 12:58 PM
<StevieG>'s Avatar
best looking front end swap on a del Ive seen was a EG front end.... just sayin... it doesnt look like crap.....and it almost looks factory... just a opinion
http://civic-eg.com/viewtopic.php?t=...1bf5aa1c07ad69
Old Oct 20, 2010 | 08:02 AM
Player_One's Avatar
The thing is, the frame rail has a bit of damage anyway. And the other reason I'm considering doing this is because the EK engine bay looks a lot cleaner. But I might be able to clean up the driver side with just the sheet metal above the frame rail. The passenger side would still be an issue.
Also, I'm not changing the appearance of my car. The Del Sol will remain looking like a Del Sol. The only benefit in a front end conversion is for hood clearance but that's only for the EK/DC2 front ends. EG also has hood clearance issues.
Speaking of hoods... I also need to know which hood hinges are compatible with the Del Sol as the hinges themselves are stamped SR2 (Mostly a Del Sol specific stamping) instead of SR3 (EG). I lost my hinges somewhere. I hope I didn't throw them into my scrap metal box.
Old Oct 20, 2010 | 08:35 AM
so you want to do an engine bay conversion......
Old Oct 20, 2010 | 09:26 AM
Player_One's Avatar
Yes. People have done more extreme things for aesthetics. Plus, my passenger side rail is already bent. I managed to get my engine mounted but I can tell by my replacement radiator support the rail is off. Plus, when I cut off the B/D bracket, I ended up with a few ugly holes and craters in the frame rail since I couldn't find my spot weld bit. The driver side may be much easier.
It's not some budget build as you may be thinking. It's already 5 lug with RSX-S front brakes and DC2 ITR rears, ITR quick steering rack, EK steering column to use current generation steering wheels, S2000 cluster and seats and more ATM. There's even some CRV and TSX parts.
Old Oct 20, 2010 | 09:31 AM
It just doesnt seem like a safe idea to cut up frame rails and weld new ones on. I know being different is the thing to do but being safe seems more important.
Old Oct 20, 2010 | 09:44 AM
Player_One's Avatar
They'd be welded on like factory. Assuming everything fits properly. At the moment, I don't even have a clue if the stock strut towers will seamlessly line up with the EK frame rail. Plus, if I fail, I have a spare Del Sol to swap everything over to.
Old Oct 20, 2010 | 09:51 AM
arent the frame rails from the factory all one piece? so if you are welding back together its not like factory at all. Look man do whatever you want it just doesnt seem worth all the work, but keep us updated if you attempt it.
Old Oct 20, 2010 | 10:39 AM
Shade93's Avatar
waste of time
Old Nov 20, 2010 | 11:36 AM
Jair [Project1]'s Avatar
I've seen it, it looks sick lol
Old Nov 20, 2010 | 12:10 PM
hai_tech's Avatar
oh my here we go again lol
Old Nov 21, 2010 | 02:11 AM
Ozne99's Avatar
Why the **** would anyone do an engine bay conversion? Are you gonna do a trunk conversion after?
henry9419
Jun 6, 2012 04:30 PM
blaze2010
Dec 25, 2009 03:54 PM
austinkli
16
Mar 10, 2008 08:05 AM
gutta
Jan 20, 2006 03:14 AM
Area51typeR
Feb 14, 2003 01:43 PM
