iac valve question
Old Oct 17, 2010 | 10:54 PM
mccordelectric's Avatar
Default iac valve question
anyone ever try to blow thru your iac valve? from what I understand, it should be open when the engine is cold. I unbolted it but left everything else connected. I turn on the key, it is getting power. I took a piece of vacuum hose and pressed it hard against one passage and blow on it, it is closed. at the same time I can hear a whining noise coming from the valve that goes away when I unplug the electrical connector. the valve is either not opening, or totally plugged but I did clean it out and did not get much dirt at all. wondering if this could cause my no start(plugs getting fouled) condition. I am thinking yes.
Old Oct 18, 2010 | 06:15 AM
Former User's Avatar
Default Re: iac valve question
Unbolting the IACV from the IM or TB would create an intake air leak and high idle. The ECU would attempt to respond to this situation by closing the IACV, so I don't believe that your test reveals a problem.
Also, if you hope to get useful replies, then provide all relevant information about your car and engine:
https://honda-tech.com/forums/showpo...48&postcount=2
Please familiarize yourself with the stickies at the top.
Old Oct 18, 2010 | 08:33 AM
no kidding, did it with engine off. I was testing to see if the valve was open since I have an engine that wont start and fouls the plugs.
Old Oct 18, 2010 | 08:56 AM
To avoid confusion, provide precise details. Why would you expect the IACV to be open in this situation?
More important, look elsewhere to solve your problem. For example, do you have spark and fuel? Any CEL codes?
redex94
Mar 22, 2005 10:28 AM
1999gs-r
Oct 20, 2004 06:25 AM
TURBO-JET LUDE
Oct 24, 2002 12:50 PM
SurferX
Aug 28, 2002 04:36 PM
Ri5e
Jun 28, 2002 11:32 AM
