stock exhaust bolts
i've not have any of my stock bolts with the spring inside of it and my current exhaust is held by bolts from homedepot and a nut/washer tightene dto the other side
would this be ok with putting back a stock gsr exhaust ? does anyone remember if there were any donut rings or any gaskets of sorts to use on the stock exhaust?
thanks
thanks
You don't have to get the OEM blots with their springs.
The home depot bolts will, someday have to be cut off, because of rust. You could have gone to a regular hardware store and bought stainless steel stuff and avoided the rust.
Starting at the point:
Where the header meets the cate, you will need a 2" donut.
Where the cate meets the 'B' pipe, you will need a 2" gasket with 3 bolt holes.
Where the 'B' pipe meets the axle-back, you will need a 2" donut.
These parts are alot cheaper at the local auto parts store, than at the dealer.
argh i need a 2" donut, i'll go look at an autozone or something. i already have a gasket for 3 bolt holes but its probably bigger than 2" would that work?
and the bolts from home depot are stainless steel
would the 2'' donut/gasket fit on or no?
They make all diffrent size donut gaskets just go ask for a 2 and a quarter one
do sprays that convert rust to primer work on exhaust? i'd like to get rid of all the damn rust off of my stock exhaust before putting it back on and spraying it w/ some sort of paint or anything of that sort
anyone have recommendations?
I've never used rust converter on a exhaust but you could use a wire wheel to get the rust off and put a coat of paint.
yea mines bad
wire wheel? i'm not down for labor considering i have random patches of surface rust across the damn thing (not sure of the inside) anyone have feedback w/ sprays that remove or turn rust into primer? is THAT EVEN REAL? how the hell can rust even turn into primer lol..
yea mines bad
Its doesn't exactly convert rust it just primer that coats and covers it, but like I said I dunno if its good to have on a exhaust, the heat cause cause fumes or a smell, and it might crack the primer
au-gsr
Nov 13, 2002 04:37 PM
